Hdx 9000 has stopped recognising fingerprint log on
How to reset the password of polycom hdx 7000
You can use the hardware restore button on the Polycom HDX system to reset
the system in one of these ways:
• Restoring configuration-Restores the configuration, which resets most
system settings to default values.
• Factory restore-Completely erases the system and restores it to the
software version and default configuration stored in its factory partition.
If you follow this procedure while a USB storage device is connected, the
system restores from the USB device instead of the system's factory
partition.
The restore button is on the front of the Polycom HDX 9000 series system, as
shown in the following figure.
The restore button is on the front of the Polycom HDX 8000 series, Polycom
HDX 7000 series, and Polycom HDX 4000 systems, as shown in the following
figure.
The restore button is on the left side of the Polycom HDX 4500 system, behind
a wire mesh screen, as shown in the following figure.
Use a paperclip to press the restore button through the wire mesh covering
that side of the system. to reset the HDX Series system we can press the restore button over 15 second.
Feb 27, 2014 | Polycom VSX 7000 Video Conference
Hdx 9000 pawor - on password
for computer password, Windows Password Recovery Tool Ultimate can has helped me solve login problem quickly!
Dec 04, 2013 | Computers & Internet
Asking fingerprint password
Is the problem that it is asking for a fingerprint password?
You can skip the fingerprint password and log in manually by typing the sequence of Ctrl + Alt + Delete 2 times. This will let you put in an user and password.
Did someone perhaps set fingerprint password while you were not looking?
Mar 04, 2011 | HP EliteBook 6930p Notebook
HAVEA TOSHIBA LAPTOP WITH A FINGERPRINT IDENTIFIER TO OPEN WINDOWS, WANT TO CHANGE THE FINGERPRINT TO MY DAUGHTERS. HOW DO WE ACCESS THIS?
dentifying the fingerprint readerA fingerprint reader provides extra security for the PC. The VeriSoft Access Manager by Bioscrypt uses the fingerprint reader to identify the user, and controls access to Windows or other secure systems. Instead of typing a User ID and password, you can move your finger across a sensor to logon or start commonly used applications. Verisoft Access Manager can manage all of your different secure accounts and the required user names and passwords by recognizing your fingerprint.On HP notebook PCs, the fingerprint reader is a small metallic sensor located near the keyboard or display. By swiping your finger perpendicular to the metallic sensor you can logon to the PC, a network, or open a program. c00897920.gifBefore you can use the fingerprint reader, you must set up the fingerprint reader by registering your fingerprint with the Access Manager. Set up the fingerprint reader To set up the fingerprint reader to recognize a user, the user must have a logon account on the PC and the account must have a password. Multiple users can be registered for the fingerprint reader if each has their own user account.
  1. In Windows, double-click the VeriSoft Access Manager icon c00897921.gif in the notification area of the taskbar to open the My Identity window. Alternately, click Start > All programs > Verisoft > My Identity .
  2. Click Log On to open the VeriSoft Logon Wizard. Click Next to begin.
  3. Enter the User's Windows password in the Password field on the Introduce Yourself page, and click Next . If you have successfully logged on to Windows, click Finish to close the wizard.
  4. Click Register Fingerprints on the My Identity window, to open the VeriSoft Logon Wizard. Click Next to begin. c00897922.gif
  5. Select a finger shown on the hand graphic, and then slowly swipe your finger across the sensor. One of the squares below the hand graphic will change color when the scan is accepted. A message displays if the scan is not accepted.
  6. Swipe the same finger across the sensor again until all four squares change color, then clickNext to register the finger print. If you need to start over during the fingerprint registration process, right-click the highlighted finger on the screen and then click Start Over .
  7. If prompted to register a second fingerprint, click a different finger on the hand graphic, and then repeat steps 5 and 6.
  8. After using the Registration Wizard to registered at least 2 fingers, click Finish .
  9. To set up the fingerprint reader for a different Windows user, log on to Windows as that user and then repeat steps 1 through 8.
After registering your fingerprint you can log off and then use your registered fingers to log on to Windows. Using Fingerprint reader before registeringIf you swipe your finger across the fingerprint reader before it is set up, the Access Manager opens a logon wizard window and prompts you for informa
Feb 03, 2010 | HP Pavilion DV5234US Notebook Laptop
Fingerprint reader
have you reinstalled the driver? if you reformatted the OS then all the drivers would have been deleted
Sep 21, 2009 | Office Equipment & Supplies
My fingerprint reader wont recognise my fingerprint. "bad read" o
Check with a service person if the finger print reader is still functional
Jun 24, 2009 | Toshiba Satellite A100-S8111TD Notebook
Log on screens are not recognisable by finger print reader
ok.. please update your related drivers firstly.. but the actual trick is to go
Manage add-ons, and find your related add-on for Explorer (DigitalP in my case on my HP Laptop) and ENABLE it..
also right click My computer on your desktop, then click Manage,
then find and load Biomethric Authentication Service, under services.. (DPHost in my case)
i am almost positive in most cases, enabling your digital finger print reader on MANAGE ADD-ONs secction must help..
Mar 17, 2009 | Microsoft Fingerprint Reader Win...
Biometric fingerprint reader not recognising me
Restart you computer and tap the F8 key until the startup option screen appears,then start in safe mode.
Jan 05, 2009 | Dell Latitude D600 Notebook
Fingerpring login problem
You can downgrade your fingerprint software to previous version. It can be found here:
Version 3.2.0.116 (32 bits version):
HERE
Version 3.2.0.116 (64 bits version):
HERE
This solution was tested on few laptops. It is not best way but it works. We are still waiting for new version of this software.
Sep 16, 2008 | Lenovo 3000 N200 T7100 1.8G 1GB 160GB...
Usage
It's different from product to product. But the good ones can be programmed to recognise up to 25 different fingerprints. So there's no need to cut your finger off to give to the girlfriend.
Aug 27, 2008 | Deadbolt Fingerprint Keyless Lock
Computers & Internet Logo
David Payne
David Payne
