Question about Sony Handycam CCD-TRV318 Camcorder
Same thing I get as c:31:22 error code with the beeping and the tape eject icon, what i found here is what i find on sonys website. It didn't work, any other ideas?
    Champion:
  • 287 Answers
That is a capstan error code. doesn't always need a capstan however. may need cleaning, Many times the takeup tension needs adjusting ,if it's to low it will produce the code.
Posted on Jul 21, 2009
Sony ccd-trv43 showing c:32:00?
Error Code = C:32:00 - Tape will not eject... I found that the Camcorder ate the tape and the tape was rapped all up inside the Camcorder, preventing the tape from ejecting. I took the Camcorder entirely apart and removed the tape manually and re-assembled the Camcorder. When finished there were no extra parts or screws and my Camcorder works perfectly once again. However, I DO NOT RECOMMEND this procedure if you are not confidant that you can disassemble and re-assemble your Camcorder.
Dec 05, 2009 | Sony Handycam CCD-TR416 Camcorder
Sony Camcorder DCR-TVR140 NTSC does not recognize tape in camera
daer
this error C:31:23 is related to the s reel and this occurs only when the tension of the tape is more,
solution:
1 st try to change the tape
if the problem persists then u need to take it to the service center as the tape path of the mechanical section is to be adjusted
as you are telling that your camcorder is not showing remaining time (time code ) then head assy. also need to be cleaned ..try to use cleaning tape for 10 sec. not more then that .
Jun 24, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
I have a Sony CCD-FX410 8mm camcorder. It is in excellent condition. I was going to transfer all my 8mm tapes to DVD and decided I should get a head cleaner for it. Found one at BestBuy, put it in and it...
This is my 3rd try to get a solution. I have a Sony 8mm camcorder, CCD-FX410 and a head cleaning tape is stuck in it and I can't get it out. This camera is in EXCELLENT condition. I tried going to Sony's website and they no longer offer service on it. Both of the other people who answered this told me to turn power off, unplug cord, turn on to VTR and wait 15 seconds, then plug cord in again. It didn't work. After I put the head cleaner in, it wouldn't play and kept trying to eject. Finally it just started beeping and flashing an icon in the viewfinder. Manual says to send for repair. Any ideas on what I can do? Can not get tape ejected. Thank you.
I know CCD-FX410 camcorder was launched in July 1992 and I also know what is the reason of problem in your camcorder and I'm afraid it can not be solved because its an old piece now. Parts are no longer available and problem is leaky electrolytic capacitors on its circuit boards. Time factor is involve here, it is not operational mistake.
I can help you out to eject stuck head cleaner tape in camcorder. If you are looking to bring it back in business then it is not possible because an experienced camera tech can repair it and will charge you more then camcorder worth.
Hit "add a comment" button to assist you in ejecting tape. You need to apart camcorder and should have 4 or 6 volt DC supply in hand.
Thanks.
Apr 19, 2009 | Video Cameras
The tape will not eject, battery is charged, help! Thank you!
Unplug battery and reattach it again, then try to eject the tape.
If problem still exist and camera shows error code "C:..:.." and beeps then it is problem of tape mechanism.
Dec 13, 2008 | Sony Handycam DCR-TRV50 Mini DV Digital...
Sony Handycam DCR-HC32 Not Working, Not Ejecting Tape, LCD Flicker
DCR-HC32 need new tape mechanism as shown in below exploded view.
Its part number is as follows..
A-1082-424-A MD (Z210) SUB ASSY
Nov 06, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Tape will not eject
If you open the eject thingy like normal then look for a small white plastic tap. its located right underneath the "start/stop" text you see on the back end of the camera (where the record-button is). You´ll need something like a small screwdriver or similar. Press it and and the tape ejects like normal. Worked for me. Saved me the repair bill :)
Jul 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Feb 29, 2008 | Televison & Video
Warning indicator C:32:00/C:32:11
I had the same problem (error c:32:00, beeps and tape would not eject. Cassette was halfway ejected) on my Sony CCD-TR416. I found the fix here:
http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR_PC5E_Error_code_C_21.00.html
To summarize: remove the battery, unplug from the wall and smack the **** outta the bottom of the camera. It worked for me. It looks like my problem was that the tape had started coming out of the cassette body and caused a jam.
Feb 05, 2008 | Sony Handycam CCD-TRV43 Camcorder
Error code C:32:20
My best solution, is to pull all power sources form the camera for 24 hours. If this does not work, then take the small screws surrounding the Tape housing, in order to try and get the tape out. Best of luck dude ;)
Feb 05, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-TRV318 Camcorder Logo
400 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
