Question about Toshiba Satellite M35X-S161 Notebook
Laptop won't boot
My laptop will not boot up. The battery doesn't seem to be charging. Is there any way to get what I need off my computer and onto an external hard drive so I don't have to bother getting this thing fixed again?
  • 883 Answers
You can purchase an external hard drive enclosure on ebay for $5.00 US delivered cost. open your laptop, remove hard drive, insert it into the external hard drive enclosure, and connect to USB to a PC (or laptop). then get your files.
Posted on Nov 20, 2007
  • 457 Answers
Its is possible that the adapter is had it! Get hold of another to test and if goes then all you need to do is buy a new one.
Posted on Nov 19, 2007
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Will a laptop battery become damaged if you use the computer while it is plugged in? I do a lot of photo editing, and leave the computer plugged in for long periods of time, so that it doesn't di
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Laptop batteries vary from laptop to laptop. i suggest you Google the Internet for a battery for your model laptop.
Oct 25, 2012 | Acer Ac Adapter Charger For Extensa...
My gateway 4525 battery is 95% charged but won't tune the computer
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Jul 04, 2012 | Gateway 4525GZ Notebook
Charging problem of dell pp41L, it works as an ac online power bt it doesn't charge it.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 20, 2012 | Dell Computers & Internet
The battery on my laptop stopped charging, but was working for a over a week, then it was acting funny and slow.. I shut down moved to another room and it won't boot up! The light doesn't come on...
I think your power cord is bad. It probably was not charging the battery at all and so now all your battery power has drained since you were running on it. Once the battery power is drained and if the AC Adapter Power Cord is not working the computer will not boot because it has no power source.
Some AC Adapter & Power Cords have lights on them to let you know when it is plugged in if it is working. Normally when you plug the power cord in the laptop somewhere on the laptop lights up to let you know it is receiving power. Sometimes the light is where you plug it in, sometimes at the front of the laptop or right above the keyboard area.
I thing you need a power cord. And don't settle for one of the one size fits all (with a removable tip designed to fit any laptop) that the big box stores will sell you.
If your power cord is good and the laptop is not receiving power then the problem could be your DC Power Jack where the power cord plugs into the computer.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Apr 03, 2012 | Acer Computers & Internet
Hi I have a Toshiba laptop model no.psl2xu-ookoof and it doesn't charge anymore so what do I do
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
Mar 26, 2012 | Toshiba Computers & Internet
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
Put your Windows disc in the disc drive.
Tap F12 when the computer is starting up.
Select load from disc.
Install Windows.
It seems to be the only solution to your problem.
Hopefully, you made a partition and saved your files onto there, or onto an external hard drive to prevent data loss.
Jul 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Won t charge
Download Motorola Phone tools and get a new battery for your phone.
The batteries go bad about once a year, sometimes longer.
if this helps you please leave a vote on fixya
May 21, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Toshiba Satellite M35X-S161 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
