Question about Kenmore Elite 45986 Front Load Washer
I have a 110.47532600 washer and the door gasket is leaking (ripped) Can I buy a replacemnet
  • 5,911 Answers
You certainly can. Searspartsdirect.com carries the part for about $64. Just type in your model number and look under the "Door and Latch Parts" section for item 1. You may also consider items 2 and 8. Item 2 is the rear bellow clamp. Item 8 is the front bellow clamp. Order only if your existing clamps are damaged or broken. If you need instructions on how to replace the bellow, the following link explains:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Jul 20, 2009
Wbvh5300k2ww washer leaking
door gasket or door boot or the door bellows, it can be referred to by any of these 3 names
Nov 11, 2012 | Washing Machines
My ge front load washer has a substantial leak when it is running. it is leaking from the bottom of the unit. It is not the drain hose or a clog in the drain. But it leaks like crazy PLEASE HELP
Check the door gasket for rips. Also there is a gasket between the two halves of the the outer drum, check that for leaks. Look at the pump housing and the hose that connects the pump to the drum for leaks.
Aug 27, 2010 | GE WSXH208A Front Load Washer
Water leaks from under the door when in rinse with water at half level agitating . i think gasket is problem and i order gasket but to open and taking out and putting back is hard . tips please
Check the glass door for a build up of soap residue as this will tend to make the door leak. Also check the door boot gasket for any tears or rips. If you have the gasket call a service technician such as Sears to install it as you have to know how to do this !
Jan 29, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Door gasket is ripped and water is leaking. i need a part number for new gasket and possibly a diagram of disassembly. washer machine no. wcvh626ofww
you can buy your door boot seal from Repairclinic.com #1394050 cost is $ 98.05 or try your local appliance shop!
Jan 19, 2010 | GE WCVH6260FWW
Door leaking on model WM0642H
HOW BAD DOES THE DOOR GASKET LOOKS? IS IT MILDEWED, HARDENED, OR LITTLE RIP? IF SO, YOU NEED TO REPLACE THAT. YOU CAN ALSO BEND YOUR DOOR A LITTLE. GENTLY AND CAREFULLY THOUGH, YOU DON'T WANT TO BREAK IT
Jan 14, 2010 | LG Washing Machines
Rubber ring ripped
You can buy and fit a new door gasket if you have the required mechanical knowledge
Take the power off , the top off remove the fitting band take off the old gasket and re-assemble in the reverse order
Jan 03, 2010 | GE WSXH208A Front Load Washer
Kenmore HE 2t washer is leaking from the front
thats called a bellow. from a scale of 1-10 id say a 9. front assy of washer needs to come apart to be able to get to gasket rear. that is why it leaking just a small tear or bend on the gasket bye the door will cause it to leak. ive done about 50 of those and it takes me about 1 hr. good luck .if u need furthur assistance let us know. thank you.
Oct 07, 2009 | Kenmore Washing Machines
Kenmore Elite HE3 water is leaking out the front door
These are notorious for the door boot leaking. Look for any tears, rips, pinholes in the door boot. Also make sure the door is parallel with the machine. Most likely it's the boot. Parts about 100.00. Labor can run from 110-140 depending where you go.
Mar 16, 2009 | Kenmore Elite 45986 Front Load Washer
My front load kenmore washer door gasket is garbelled
Something probably got caught in the seal and pulled it out of place. If u run washer so that it fills up and starts tumbling,,, and there is no water leak,, there is a good chance u can repair this yourself. So if there is no water leaking,,, you can try and take out the bottom front panel and twisting, or shoving it back into place. If there is water leaking,,, than chances are its ripped or broken, and will need to be completely replaced
Mar 13, 2009 | Kenmore Elite 45986 Front Load Washer
Door gasket leaks at the bottom when spray nozzle goes on
happy new years,,i believe you mean when the recirulating pump comes on about 4 to 8 mintues into wash.....open door and fell if any lint stuck up there if so use a needle nose pliers to pull out..check the bellows or gasket around door and make sure your not ripped ,,or missing a peace...now this is cheaper than buying new gasket...unplug unit ..than remove door switch and put 1 washer on the back of each screw ,,but put washer on inside of unit between panel and door latch ...this will push latch back and make door come forward so to be tighter...im here,,onthejob
Dec 27, 2008 | LG WM-2277HW Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
199 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
