Question about Miele W4840 Front Load Washer
Miele W4840 is LOCKED
I am unable to do laundry. How do I unlock my washing machine?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
Hi try pressing in the heavy soil button to take off the child lock, good luck
Posted on Jul 19, 2009
How do unlock the washing machine IQ300
Do not open the washer door by force while it is operating (high-temperature washing, drying, or spinning). Within 5 minutes as you start a wash, it is possible to add/remove laundry items. Simply do the following: Step 1: Press the Start/Pause button to unlock the door
Mar 25, 2016 | Washing Machines
I am unable to unlock the washing machine door and do not have the user manual. I need to unlock the door so that I cna close the door and run a lkoad of laundry.
You need to PUSH IN the program knob (top right) (pointing it to a dot between programmes to be sure but that might not matter) and wait for a minute. Manual is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90256-1.pdf
Jan 12, 2011 | GE Profile WPXH214F
My machine is showing the code FL machine has problems locking. How do I resolve this problem
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a musty or moldy odor coming from the washing machine. Is it possible to have some clothing in between the drum and the outside walls of the washing machine
I don't know if that is possible but trying running just bleach water through and start leaving the door open after taking laundry out. If it is unable to dry out then it will build up mold and mildew.
Nov 11, 2010 | Maytag Washing Machines
The twin tub connected to the washing machine doesn't drain.
The laundry tub does not have adequate drain size to handle discharge from the washing machine. In addition, the kitchen and laundry area piping may not be correctly vented.
May 17, 2017 | Daewoo DW500M Top Load Washer
I am in the middle of a load of laundry and it has stopped and the error code reads "suds". I am unable to get the machine to work again. How do I fix this?
When the door finally unlocks run bleach and hot water through a load and then use only 2 Tablespoons of HE detergent. No matter what. You are either using too much soap or your not using HE detergent.
Aug 19, 2009 | Maytag MAH8700A Front Load Washer
Our Maytag Bravos washing machine will not unlock. The lock light is not lit up. We ran a load twice and it still did not unlock.
du is the code for cannot unlock,,,,is there excessive weight on the lid, such as a basket of laundry? Excessive weight will keep the lid from unlocking. Press POWER/CANCEL once to clear the code.....
Dec 11, 2008 | Maytag Bravos 4.5 Cu. Ft. Washer
Kenmore Elite HE4t Washer - "Control Locked"
I pressed and held drain/spin and it unlocked the controls... try it and let me know.
Nov 25, 2006 | Kenmore Elite 45986 Front Load Washer
Miele W4840 Front Load Washer Logo
1,074 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
