Question about Jenn-Air JED8430 Electric Cooktop
Jenn air electric cooktop
I think my cooktop shorted out last night. There was a popping sound and a bright red flash came out from under the burner. I reset the fuse box and the same thing happened. There is rubber burning smell.
  • 2 more comments
  • lisagoulden Nov 26, 2007
    Thank you for your advice. You were correct.
  • Anonymous Nov 28, 2008
    I have the same problem. Not sure how much it costs.
  • NoMoreJenair Feb 26, 2009
    I have now lost 2 burners, both front, with same popping and fuse-tripping. I am thoroughtly disgusted that a new cooktop (3 yrs old) has done this. The switch in the main fuse boxthat was tripped won't reset. I cannot cook at all! THIS SUCKS, as do all of my Jennair appliances in this new house!
  • Edna Mason Sep 22, 2013
    I have had JennAir 2 burner cook top for 45 years. just recently the large burned gave out and i cannot find part
  • 883 Answers
First, disable power to cooktop. next, replace either the mangled burner or the entire unit (after initial inspection leads to a logical prognosis)...sorry.
Posted on Nov 20, 2007
The left side of my cooktop shorted out. Initially popping sound and electrical burning smell. Now shorted out with loud popping sounds and large flash of red under the cooktop. Did not start a fire but...
What you had was a slow short - practically the same thing as in a welder: big and loud flame, localized and the amperage isn't that great. As such it's very possible that the breaker wasn't tripped, especially if you had a big one, over 30Amps.
No, you shouldn't even try to repair it, that unit is dead as a dodo.
Aug 24, 2010 | Jenn-Air JED8430 Electric Cooktop
Large electric burner will not turn on
you need to check the wiring to that burner it appears that there has been a short to the burner
Apr 04, 2010 | Jenn-Air 35 in. JEC9536ADS Electric...
2 right burners on my Jenn-Air JEC9536 cooktop stopped working.
I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
Sep 25, 2009 | Jenn-Air 35 in. JEC9536 Electric Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Gas Jenn Air Cooktop Issue with Electric Starter
Did you spill water near/on knobs? if so leave to dry out for 24 hours. If still clicking after 24 hours one of the switches has shorted out and needs to be replaced. You can find which one with a multi meter/condinuity test. Hope this helps...Good Luck
Jun 26, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Tripping breaker
Replace the burner and receptacle and you should be short free. You may also need to replace the surface element switch too if it doesn't come on at all or stays on high regardless off knob setting.
Dec 16, 2008 | Jenn-Air JED8430 Electric Cooktop
Boiling liquid ran down into ignition switch, now light stays on
is this the front right burner? i looked at one yesterday where milked spilled into burnt out the little board under the know. i am not sure of the model # on the one i worked on.
Oct 12, 2008 | Jenn-Air JED8430 Electric Cooktop
JED8430BD has 3 wires no ground. Wall has 3 wires including ground
I think the white on the cooktop should be on ground.
cooktop wall
Red White
Black Black
White Ground
Sep 04, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air electric stove top - burners/fan won't come on
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Apr 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
656 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
