Question about Jenn-Air 24 in. JDB1100AW Built-in Dishwasher
Jenn Air dishwasher leaking
I am so frustrated with Jenn Air. Anyway, I have a JDB125AWS dishwasher and it leaks everytime I turn it on. I have done just about everything. Cleared drain hose, checked to make sure drain clear. One guy mentioned an emptying valve on this dishwasher. Can anyone tell me where this might be?
  • 22 Answers
The emptying valve is underneath in the middle normally and it is what the drain hose connects to on the dishwasher. The drain hose itself is connecting with either a c clamp or hose clamp, check to make sure it is tightened all the way. Also do you have an idea of what part of the dishwasher the leak is coming from? If it is not the drain valve, then check to make sure it is not leaking from the door itself, as the door just has a rubber gasket that seals it and it might be that the gasket is bad. If it's not the door and not the drain valve, it could then be coming from the drainage pump or the motor for the dishwasher, which means the seal is broken and the motor or pump would need replaced. If you are unsure of how to do so then i would contact a repair technician to fix it for you.
Posted on Jul 19, 2009
Leaking at the bottom of the door and unsure where plastic door seal goes.
This dishwasher will leak if there is to much water in the unit.
I have the same dishwasher with a different problem.
Mine won't circulate the water. I have not use it for a while and some water will back feed from the sink and fill the dishwasher, so if I don't check for that problem once in a while I see it start to leak.
It never has done that when the unit was working....
Aug 28, 2011 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dishwasher leaking
Clean the float...
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
May 23, 2010 | Jenn-Air 24 in. JDB1100AW Built-in...
Front of dishwasher leaking from sides.
I think it is the seals...even though they look good they can be compressed and loose the eleasticity to swell and seal....
Here is a tip that I wrote about leaking dishwashers
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Apr 22, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Leak at the door
Leaking Dishwasher
heatman101
ttth
Dec 26, 2009 | Jenn-Air 24 in. DW861 Built-in Dishwasher
Dishwasher leaks from the bottome of the door
if it leaked everytime then it would be your door gasket.but not everytime it's your door latch not engaging completely everytime.open the door and look and see if you can access the tightening screw for the door latch.probably not but look anyway.if you can then tighten the latch.
Nov 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Our Jenn Air dishwasher leaks. We notice an
There are two possibilities here. First of all make sure the latch is adjusted to close the door tight. IF not, you can adjust it using a screw driver. next, you may have to replace the gasket as these do wear out.
Nov 03, 2009 | Dishwashers
My Jenn-Air dishwasher has sprung a door leak! :-(
it's just a door gasket,you might still find it a appliance repair place.
Jul 14, 2009 | Dishwashers
Jenn-Air 24 in. JDB1100AW Built-in Dishwasher Logo
825 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
