Question about Jabra BT150 Wireless Headset
Trying to pair device with the Nokia N95
Have deleted from old phone but the N95 will not pair with the BT150??
Can you help please??
Thank you
  • andot Jan 10, 2008
    my Jabra BT150 wireless headset was connected to my old cellphone which was broken. How can i connect my Jabra BT150 wireless headset to my new nokia N73?
The N95 has some compatability problems, i.e. it will pair with my newer Nokia CK-7W car kit but not with my older CK-1W car kit.
Posted on Dec 15, 2007
I lost my old phone I got mynew phone I could not connct my bt150 to my new phone. I need help to pair to my cell phone
Please comment here putting the name and model of the mobile phone you are trying to pair.
With this i can give you step by step instructions on how to go about the pairing.
Jan 18, 2011 | Jabra BT135 Bluetooth Headset
How to switch on jabra bt150 blutooth handset
First Fully charge the BT150. Turn BT150 on by pressing the "answer/end button". To put the BT150 into pairing mode press the answer/end and volume+ at the same time to activate pairing mode. Next Set your mobile phone to detect a Bluetooth device. Press yes or ok to pair phone with Jabra BT150. Put in pass key 0000 (four zeros) Then press yes or ok. Your phone will confirm when pairing is complete. Enjoy your earbud/headset.
Dec 26, 2010 | Jabra BT150 Wireless Headset
I can not pair a particular bluetooth device to my n95 8 Gb phone, but i was able to pair nokia's model. is there any reason why other type bluetooth devices won work with n95 nokia 8 GB cell phone? How...
jus change th settings of ur bluetooth on ur device an on th other device an try to pair it.. so tat u may recover tis prob... kindly rate me.... thank you...
Jun 30, 2009 | Nokia N95 Cellular Phone
I am trying to pair my z9 with my nokia n95
  1. Delete the old Z9 pairing
  2. With the Z9 OFF, Press and Hold the MFB for about 6 seconds. The LED will appear a solid Blue, and then will start flashing. The Z9 is now in Pairing mode and ready to be found in searches by other Bluetooth devices. Pairing mode will be active for 2 minutes
  3. Enter Passkey "0000" when your phone prompts you. The phone and Z9 will now Pair
I hope that helped.
Feb 28, 2009 | Blueant Z9 Wireless Headset
Unable to pair with CK3100
You need to reset the Parrot first.
Hold down red and green buttons together until she tells you that the memory is being cleared. Then she will prompt you to pair your phone.
Feb 05, 2009 | Parrot Ck3200 Ls - Color Cell Interface...
2nd hand BT150
Default Code is 0000
Jan 22, 2009 | Jabra BT150 Wireless Headset
Cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
Dec 07, 2008 | Jabra BT150 Wireless Headset
Supertooth btslbc3
Hope this helps..............
-----How to Create a new Connection----
Pairing with Phone
1. Turn off all devices (ST Light and Phone)
2. Turn on Phone
3. Goto Bluetooth menu on the phone (might be in connectivity)
4. Go to device list or paired devices (make sure bluetooth is turned on)
5. Delete any old profiles that are still in there.
6. Goto the Supertooth Light (BlueAnt)
7. Hold down the green button (send button)
8. while holding it down, open the microphone
9. the light should start to flash "red" and "blue" (you can release the green button)
10. go back to your phone, and go into either 'device list' menu or 'paired devices' menu on your phone.
11. click on either search, add or new devices. Function depends on different phones
12. when the phone has found the device, it should say 'ST Light BA V1'
13. select it, then enter passkey "0000"
14. If your phone ask for authorization or auto connect, just click "yes"
By now, you should be connected to your device. Always remember to close the microphone before you leave the car.
Otherwise, it will slowly drain the battery. If you want to reconnect, just simply open the microphone.
Make sure you turn off your phone once every 2 weeks to reset the phone memory. This will help give a better
performance and clearer sound.
Oct 30, 2008 | Radio Communications
Cannot Get Jabra BT150 into Pairing Mode
I had problem with my bluetooth not getting into pairing mode,and Now it working good.
Thank you for your best solution.
Jul 28, 2008 | Jabra BT150 Wireless Headset
Lost instructions BT150 how to connect to phone?
1. Turn the BT150 on. To do this press and hold the answer/end button until the light flashes blue, then release.
2. Press and hold the answer/end button and the volume up (+) button until you receive solid blue light. This may take up to 10 seconds.
3. Go into the Bluetooth menu on your cell phone and follow the cell phone’s instruction guide for pairing a Bluetooth headset. This generally involves going into a “devices” or “hands free” menu and adding a new device. Your phone may ask if you want to pair with the headset, accept by pressing “yes” or “OK” and confirm with the passkey or PIN 0000 (4 zeros).
Apr 27, 2008 | Jabra BT150 Wireless Headset
Jabra BT150 Wireless Headset Logo
390 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
