Question about Car Speakers & Subwoofers
No sound from my 2005 Corolla speakers
Hi. I have a 2005 Toyota Corolla and recently the sound stopped coming from the speakers. The radio turns on and the digital clock works--but no sound. When I turn the radio off and on a very slight clicking noise comes from the speakers but that is about all. Any ideas on how to fix? I called my local Toyota service center and they suggested buying a new factory radio to the tune of $1500. I thought I would try to troubleshoot common problems before making that kind of investment.
Many thanks in advance!
  • 65 Answers
Re: No sound from my 2005 Corolla speakers
The likely problem is that somehow one of the wires going to the speakers has "grounded out", meaning a wire for some reason is touching the car chassis, therefore shorting out the circuit the same way a lightning rod conducts the lighting into the ground, instead of your home.
A decent car stereo installer should be able to determine the problem. Either it's grounded out, which they can use a meter and connect the probes between ground and each of the 8 speaker wires to determine -or- the radio is faulty, and a new radio can be as cheap as $150, +fit kit, + wiring harness. Don't buy a factory radio replacement because it is a huge rip off and aftermarket ones are much better.
Posted on Nov 20, 2007
0 characters
3 Points
2001 honda goldwing radio stop working
speakers could be blown did this just happen did it work recently?
Jul 23, 2012 | Car Speakers & Subwoofers
Toyota Spacio Corolla year: 2000 radio & mirrors (electric mirrors ) not working
This sounds like it might be a fuse problem. Consult your manual for fuse box location or visit
Sep 03, 2011 | Car Speakers & Subwoofers
I have a 2001 toyota corolla hatchback , radio turned itself off, still has facory pin but i dont know it, can u help me
Well for one it can't Turn it self off you must of lost power that is the only way for it to reset. Anyways I would try all 0 for a password or 1234. There is a easier way though call the dealership for help
Aug 25, 2011 | Car Speakers & Subwoofers
2005 toyota corolla radio code
You can get this code from your dealer. You will need your VIN # and it may cost a little. But it's worth it. Hope this helps
Aug 17, 2011 | Car Speakers & Subwoofers
2005 Corolla cd player "ate"
try disconnecting the battery for a few minutes to reset the radio. Sometimes a microprocessor will lock up. You can reset it by disconnecting the battery.
Jun 01, 2011 | Car Speakers & Subwoofers
The radio, cigarette lighter and inner light of toyota corolla does not come on. what should i do?
Not to farmiliar with the car but I would check the fuses, some fuse blocks say where the fuses goes, and for some cars you have to check the owners manual, If it is the fuse the first one I would check would be the one for the radio, and if that one is good look for one that says cigar lighter or interior light. Your car should have a fuse listed as at least one of those, or possibly all 3.
Nov 08, 2010 | Car Speakers & Subwoofers
I have a toyota echo 2005, i recently changed my battery, but now the radio wont go. Where do i get the code from?
If it`s the original stereo then phone your local dealer and quote your reg and make of car... Normally free to do all this... Or check your manual as it prob happened before and was wrote down there...
Oct 13, 2010 | Car Speakers & Subwoofers
I have ford mondeo radio is 6006e model it doesnt turn off with key and when you turn on it says 1 hour before coming on how can i stop this please.
Have you been working on the wiring recently?
It looks as though the permanent battery feed( instead of the Ignition Battery feed) is connected to the Main battery lead in your radio....when it should be connected to the radio memory.
The 1 Hour means a wrong code has been entered
Jun 14, 2010 | Car Speakers & Subwoofers
Car Speakers & Subwoofers Logo
836 people viewed this question
Top Car Speakers & Subwoofers Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Car Speaker and Subwoofer Expert? Answer questions, earn points and help others
