I'm replacing a ac blower resistor on my 2004 Infiniti qx 56 but I don't know where it is located on the vehicle. I have taking the glove box out but I still have not found the location of the resistor. It is the one that looks like a credit card.
  • 6,826 Answers
Try looking under hood ,near the firewall,passengers side near windshield,
Posted on Jul 20, 2009
Where is the resister located
on the firewall close to the blower motor usually
Feb 29, 2016 | 2010 Ford F-150
The heat/ac fan works only on high. All other functions operate normally. I am told there is a module located in the duct that needs replaced. Is this true, if so how do I access it?
Try opening the glove box and looking in behind it for wires coming from blower motor and they will go to a connector that is attached to the blower motor resistor, usually mounted in the ducting with 2 small screws. That resistor needs to be replaced. You may have to empty glove box and flip it down to see it, or look up under and behind glove box.
Jun 28, 2011 | 2004 Dodge Intrepid
Where is the heater blower resistor located in a 2000 Subaru Outback? I've seen one reply in a forum saying it is to the left of the blower motor, but I don't know where that is either. I need to...
the blower motor is located under the passenger side of the dash. The blower motor resistor is located behind the glove box assembly. You will need to remove the glove box assembly and then you will see the resistor. It will have one connector with four or five wires and will be held to the HVAC unit with 2 screws.
Jun 23, 2011 | 2000 Subaru Outback
The heating and air conditioning fan only works on the highest speed position. What would cause the lower speeds not to work?
If the system is a Manual ( not the EATC / Electronic Automatice Temperature Control System ) it is most likely the blower motor resistor.
For the new body style 2004 ( not the 2004 Heritage or Lightning models ), it is behind the glove box.
Open teh glove box, press on one side, to allow the glove box to hang down.
The Blower motor resistor is located in the side of the blower motor housing.
If your 2004 is a Heritage or Lightning, the blower motor resistor is access from under the dash / glove box area.
On this type ( same as the 97-03 ) the blower motor resistor or the resistor and pigtail might need to be replaced.
Just pay attention to which body style 2004 you have ( new like the 2005-2008 or the 2004 Heritage / Lightning, which looks like the 97-03 MY trucks.
Aug 09, 2010 | 2004 Ford F150
How do you change the blower motor on a 2004 dodge caravan
hello,
1.First dissable the air bag system
2. open the glove compartment, squeeze the side in to release the glove box stops and lower glove box.
3.You will see the Blower Motor Resistor directly behind the glove box.
4.There will be two pig tails (one vehicle harness, one resistor), remove pig tails, remove two screws to free resistor.
5.Replace resistor, reverse removal procedure.
Done!!
Take care..
Aug 07, 2010 | 2004 Dodge Caravan
Have lost fan to heatr and ac...where is the fuse box or diagram?
1. Does the Blower work on High (or #4) only? If so then it is not the Front Blower Motor or the Relay that is bad, but it is the Resistor which is located behind the Glove box. Follow step #a. below and take out the Glove Box to access. It has 3 to 4 wires going into it. The wiring path is: Switches to the Resistor and then to the Motor.
2. The Front Blower Motor Relay is located in the IPM - Fuse and Relay Center. It is located in a box within the engine compartment. However: (restated) IF the Blower does only work on High then this Relay is good and you should only replace the Resistor Only. The Identification and Location of the Relays and Fuses is located on the back side (inside) of the IPM cover. Remove the cover. The Front Blower Motor Relay is the same Type (size and shape) as several other Relays in the panel. Switch out the Front Blower Motor Relay with a non-engine operation Relay for a function that you know works. Recheck the operations of both functions. If the Front Blower Relay now works and the other function now does not work, it was the Relay was bad and needs to be replaced.
a. Disconnect the Negative Cable from the Battery and wait at least two (2) minutes to deactivate the Airbag Sensors.
b. Remove the Glove Box.
c. Disconnect the Electrical Connection.
d. Unbolt/Unscrew the bolts/metal screws and remove the Resistor.
Installation is reverse of above.
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
Jan 19, 2010 | 2004 Dodge Caravan
The heater fan is not operating and I thought it might be a blown fuse. I checked the fuse box under the dash and couldn't locate the fuse for the fan by the descriptions given. Do you know which fuse on...
My 2002 I35 has the blower fuse under the hood in the fuse box in the engine compartment. The fuse box cover has the "key" or description of which fuse is which. If the blower fuse is bad and you replace it, only to have the fuse burn again then I would check the blower resistors that are located behind the glove box. Very common for one of these resistors to go bad causing only low speed operation of fan. Burns the fuse when you try to operate the fan on the higher speeds. Good Luck
Nov 17, 2009 | 2004 Infiniti I35
Blower Motor Resistor for front AC/Heater
remove glove box....its in the casing near motor.....2 screws and 1 connector
Jan 19, 2009 | 2004 Isuzu Rodeo
Oldsmobile AC resistor location
The blower motor resister is located next to the fan under the passenger side dash. You will have to remove the glove box and plastic cover under the dash to expose the blower motor. the resister is next to the blower motor.
Aug 09, 2008 | 2004 Oldsmobile Alero
Replacing all season blower motor
six screws hold the glove box two at bottom four at the inside when u open the box after the screws are out pull on the box to remove and three hold the blower motor.its not hard at all.
Jun 14, 2008 | 2004 Infiniti I35
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
