My bike won't start
First make certain the fuel is fresh ,and drain any old fuel out of the carb ,small screw at the bottom of the float bowl.when dry turn fuel on ,if flow starts again no blockage .start bike now,if no fix, remove spark plug if it is dry the carb is blocked . touch plug to cylinder head and start be carefull not to shock yourself use pliers .
If no bright blue spark check side stand cut out switch ,kill switch . if the battery has been left uncharged for more than 2-3 months replace as wont work well.
to check for seizure remove plug and push bike in first gear you should hear and feel the engine turn.
