Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Brushes don't turn.
Cleaned the filter but they still don't turn. Does it have a belt? If so, how do I get to it?
  • 97 Answers
No belt. the turbine that turnes the brushes is the problem. how can you tell......take the brushes out and try to turn the square peg with a flat head screwdriver, if it doesn't turn, it's the turbine.
Posted on Jul 20, 2009
It runs but not pick up dirt in cup
Hello! If the dirt is not entering into the dirt cup this could mean there is a clog in the vacuum or a filter that needs to be cleaned or replaced. Check that the brushes are still spinning. The vacuum has a brush-roll shut-off pedal on the right side of the cleaner if you are standing behind it. Below are simple instructions for checking your vacuum for clogs.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
9. Inspect the belt for damages, if the belt is broken replace the belt with a Genuine Hoover belt part 562633001 Flat Belt Nano Upright
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Mar 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
F7441-980 brushes won't turn
Paul:
Turn the vacuum over and remove the foot plate. Check the belt and manually try to turn the brushes. If the belt is OK, the brushes need to be removed and the roller bearings at the end of the brushes cleaned (hair, fibers, dust,) I remove the roller bearings and shoot them with alcohol while turning them until they turn free, then blow the alcohol out and lube them with one drop of light machine oil.
Nov 29, 2013 | Vacuums
The brushes will not turn. I cleaned the filter.
Is the drive belt broken between the motor and the brushes?
Aug 11, 2010 | Vacuums
The brushes stopped turning. I cleaned the filter
Can you rotate the brushes manually (grab some of the yellow bristles and rotate the brushes). If they are not jammed, then your air fan drive is clogged or broken. Air must pass through the fan to spin the brushes... so confirm air flow by powering the machine on and feeling for decent air flow. Clear any obstructions that my restrict air flow....
Nov 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40473&thid=732696
Posted by mathis_23 on Jul 02, 2008
I cleaned filter and the brushes are still not rotating.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It probably is not the filter that will start the brushes turning again, it may be a few other things. There is a switch in the front that indicates brushes on and brushes off, and the switch could be broken, it could be that the brushes come in an assembly and the assm could be belt driven and you would have to replace the belt or the drive mechanism the turns the brushes is broken. These are just suggestions and you should check the schematic in your owner’s manual under trouble shooting. If you don’t have a owner’s manual, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
192 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
