Question about Black & Decker Drills
I have a B & D Professional 1965 and need to take off the chuck. I have taken out the screw from the centre of the chuck but no still not able to remove it. Please help. Thank you
    Problem Solver:
  • 10 Answers
U probuly got sumthin jammed in side it such as a piece of wood to metel sheres (that could be a real pain in the ***) u sho really assemble it and take it out then if dat never did it talk to the manufacter.
Posted on Jul 19, 2009
How do you remove or reset a stuck drill chuck
If it is a reversible drill there is almost certainly a left-handed thread screw or allen bolt through the centre of the chuck into the drill shaft and this must be removed before the chuck can be removed.
If it is a keyed chuck select low gear if there is one, fit the chuck key and then strike it sharply with a hammer to jar the chuck in an anti-clockwise direction. Usually it takes only a couple of blows before the chuck is loosened.
Keyless chucks are more problematic. I hold them in a vice and use the drill in reverse which has proved fairly successful, though sometimes the chuck is only fit for scrap afterwards.
Lots of the keyed chucks can be taken apart for cleaning and lubricating if necessary.
Aug 28, 2016 | Dewalt DC740KA Battery 1500mAh, 12V, Ni-Cd
How to get the chuck off a dcd950 dewalt hammer drill
Only the screw in the centre of the chuck would be l/h tread, the chuck should be normal thread and come off in an anti clockwise direction. Please confirm drill model number.They did a version where you needed a service tool to remove it and refit. It is torqued on.
Nov 15, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
How do I remove the chuck from a Power Craft 810w Hammer drill
I'm not sure about power craft tools, but chucks are either screwed on or have a taper pressed fit.
If it's screwed onto the shaft, there are some tricks to getting the chuck off. (Chucks have normal threads, the retaining screw is reversed threads.)
1. Check for a flat spot on the spindle behind the chuck. If there is one you can clamp down the chuck in a vice and use a wrench to spin off the shaft.
2. Clamp down the chuck onto something and connect it to an impact wrench and try to spin off.
3. (BE CAREFUL) Clamp down on the chuck with a vice and spin the motor in reverse to try and pop it off. (Again be careful.)
4. Take it to any tool repair shop and ask them to take it off. (It's a common request.)
If it's a tapered chuck (usually on drill presses or large chucks) you can clamp something into the jaws of the chuck and hammer away from the drill. Remember to keep it steady while hammering because it probably won't come off if you're just holding in your hand. You need a strong jolt to pop it off the taper.
Apr 20, 2012 | Drills
Model # HJP001 Ryobi 12 volt cordless drill. Chuck is jammed, will not close. There is a screw down inside the chuck but it will not turn.
I just had the identical problem with my HJP001, and managed to solve it piecing together info from this thread. The cause for the chuck to jam was that the retaining screw had come loose and was interfering with the chuck. As others have pointed out, the retaining screw has a left-hand thread, ie reverse from most screws, which obviously needs to be taken into account. Simply tightening the screw solved my problem - together with some WD40 ;-)
Sep 05, 2011 | Ryobi Garden
Can the chuck be replaced on a 18v dewalt?
Hello russ_rome,
Here is the solution from the Dewalt website.
Firstly check to see if the chuck is secured with a screw, if you have a screw follow steps 1-3 else follow steps 2-3.
Step 1: Screw will have a left-hand thread and must be turned clockwise to undo it.
Step 2: Once the screw has been removed place a suitable Allen Key in the chuck and tighten the jaws.
Step 3: You should then tap the end of the Allen Key to ease the chuck off (the chuck has a conventional thread so unscrew it in an anti-clockwise direction).
Some of our high spec cordless drills will need to be serviced need to be taken to your nearest service centre to have a new chuck fitted.
Regards
Alan Hood
ami-man
UK
Jun 10, 2010 | Dewalt 18 Volt Compact Drill Kit
Removing centre screw from chuck
Drill a hole in the top of the phillips head screw with a 3/16 th's bit. Don't drill the head of the screw off, just drill deep enough for a torx bit to hold. Take a T-30 torx bit and tap in into the hole you have drilled. Then turn the screw clockwise and it should come out fairly easily.
Mar 26, 2010 | Dewalt Drills
Need to replace chuck
Not entirely familiar with this model but most chucks are secured by a screw inside the chuck. Open the the chuck to its fullest aperture and look inside. There should be a centre screw ... it will be a left hand thread. Remove the screw. Hold the chuck firmly, reverse the drill. The chuck should unscrew from the shaft. Installation is a reversal of the removal procedure.
Mar 19, 2010 | Hitachi 12v 3/8" Driver Drill Kit with...
Chuck is locked open
you have three jaws in your chuck, one of them will probably have a small burr on it causing it to stick.
try this...
tap the chuck with a small hammer then try to use the chuck key gently in the opposite key hole to the hammer blows. turn chuck though 120degrees and repeat.
if this does not work chucks are fairly universal and easily replaced (i would recommend a keyless jacobs). you can get the old one off by removing the ph2 (phillips) machine screw inside the centre of the chuck... be careful!! this screw is usually soft and counter threaded... when screw removed bash off the chuck with a hammer and cold chisel...
good luck
Oct 23, 2009 | Dewalt 1/2 Hammer Drill DW511
Bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Jan 31, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
