Question about Irons
I need a new water tank for steam generator iron 14125does anyone know where i can get one please?
I bought one in amazon .com .uk for 13 ounds
Posted on Aug 02, 2009
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
Ssteams constantly without pressing steam trigger
Sounds like your trigger valve in the iron portion (not the tank) is jammed open. It could be from mineral deposits so maybe try running it with a solution of distilled water and a couple of tablespoons of vinegar in the tank. Wiggle the steam trigger to try to release any scaling that maybe present inside the valve. If your steaming from the iron stops, you've fixed the problem so let the iron cool and rinse the tank using ONLY DISTILLED WATER which anyone knows is the only type of water to be used in ALL appliances. Minerals in regular tap water kill appliances quickly. Never use tap or bottled drinking water even if the directions say it's okay. Iron some old rags or towels with a tank of distilled water to make sure no mineral deposits or staining steam comes out after cleaning.
If this fix doesn't work, you can buy a replacement iron portion online..try 1800Parts.com. It's cheaper than buying a whole new iron but you may need a repairman...I've never tried to fix this portion of my DG5030 iron.
Aug 28, 2013 | Rowenta DG5030 Iron
My iron is getting hot but giving no steam can anyone advise
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
My argos steam generator iron is leaking and now does not produce steam, whats the problem and how can i resolve this problem?
tank or ports clogged: Disassembly and inspect , replace tank and seal if badly clogged or leaking. Emptying iron after each use allow heat to evaporate emaining water and help preventing clooging. Inspect valve and linkage: clean and replace as necessary.
God bless you
Jul 22, 2012 | Irons
I have a hinari steam generator iron and the steam has stopped coming through the iron and now coming through the base that the iron stands on!can anyone help please
Check the water reservoir of the steam generator and look for some hairline cracks. Also a clogged tubing will likely to go back water on reservoir inlet water pouring. Once you found the cracks, seal it with epoxy just enough to fill the cracks.
Thanks for asking.
Jul 13, 2011 | Rowenta Steam Generator DG050 Iron
No steam coming out and water tank not pumping water into generator to make steam
The Rowenta DG-980 Iron/Steam Generator works great from our experience (it is a consumer grade unit with commercial grade technology) and over 90% of the user reviews I have seen are happy with it, unfortunately it is a discontinued model & the newer replacement is not as good. Service seems to be rather thin, as is the case with most corporate entities; I was on the phone for 30 minutes before I was able to locate service center in Concord, CA (I am in SoCal), and is the only one in the state that does repairs on them, and I am going to check them out...stay tuned.
Dec 18, 2007 | Rowenta DG-980 Iron
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
Irons Logo
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
