This is taken off of teamxbox.com
It is an explanation of the bottom right light blinking red, how to tell exactly what it is, and so on. If there is general hardware failure on your xbox, microsoft posted on their site that you send it in for free repair and also get 3 year extension to your warranty.
Use this guide to determine exactly what is wrong, what hardware is failing, and hopefully we can figure something out. Please get back with me when you can, I would really like to get you up and running again, cause I know how it was when I couldnt play my xbox, I hated it. Good luck!
______________________________________________________
Section 4 is flashing red
- Hardware Failure
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow
the instructions for determining the secondary error code in the
section below
E64: (not yet known)
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E67: Hard Drive Error... It could be a problem with the Hard
Drive itself or a problem with the internal connection to the hard
drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard
drive, Try removing the hard drive and playing without it, This can
also be caused by a Hard Drive Eprom Error.
E69: Hard Drive Error... It could be a problem with the Hard
E71: (not yet known)
E73: (not yet known)
E74: AV cable error... There is a problem with the AV cable, try
using a different AV cable. (could also be a problem with the encoder
chip)
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard
--==SECONDARY ERROR CODES==-
The specific type of hardware failure can be determined by a "hidden" error code
- Turn the xbox 360 on, and wait till the 3 red lights are flashing.
- Press and hold the sync up button (the small white one), while holding that button press the eject button.
- The LEDs will now blink the first number in the code (as described below).
- Release the eject button and press it again.
- The LEDs will now blink the second number of the code.
- The LEDs will now blink the third number of the code.
- The LEDs will now blink the forth number of the code.
- The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing
lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
- All four lights flashing - 0
- One light flashing - 1
- Two Lights flashing - 2
- Three lights flashing - 3
0001 power supply problem
0002 power supply problem
0003 (not yet known)
0010 over heating
0011 over heating
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 (not yet known)
0022 GPU Error / GPU Overheating
0101 (not yet known)
0102 unknown error - literally means the console does not know
what is wrong. Possibly a short or cold solder joint somewhere (2
reports of people repairing this, one was removing moisture build up
inside the console, the other used a hot-air rework to reflow the BGA
Ram chips)
0110 Memory Error / Memory Overheating
1003 Hard Drive Error... It could be a problem with the Hard
1010 Hard Drive Error, Can be caused buy a currupt or missing Eprom.
1013 (not yet known)
1020 (not yet known)
1022 AV cable error... There is a problem with the AV cable, try
chip)
1030 (not yet known)
