Question about Goldstar Heating & Cooling
Fan doesn't turn
Compressor runs, feels cold but neither fan's are turning, took the case off, circulatory pipes get cold, but the switch that turns the power on, when it's set to fan only the fan doesn't power on
  • 22 Answers
Check to see if the fan motor has a separate fuse, if not then check to see if it has power (120 volts ac) with a DMM or volt meter. If it does then the fan motor needs replaced, if it dosen't then the fuse needs replaced or if it doesn't have a fuse, check to see if the switch is working correctly.
If you don't have a DMM or volt meter, or you do and don't feel comfortable testing it, then you'll need to have n a/c repair technician come out or take it into them if its portable.
Posted on Jul 19, 2009
Hi there I ve got a Samsung fridge model RL34SCSW1 my freezer is working fine it's just the fridge bit is not cooling?
Good day, please check at the back, at the bottom where the compressor is located for the pencil dryer(as in photo). Get a nice firm grip on it just be careful and feel the temp if it's cold or one side is hot and the other side cold the dryer is block. Otherwise feel the thickest pipe running into the compressor it should be cold if the fridge has been running for a while and the thin copper pipe existing the compressor should be hot. If the thin pipe is freezing up with a thick layer of ice and the dryer as some med-temp then there's a gas leak. If the thin copper pipe is very hot and the dryer has no temp then there's a blockage but if the thin copper pipe feels med-temp and the thick copper pipe more or less the same but a bit cooler the compressor is not pumping also feel if the compressor is running. If dryer as a warmth temp and the thin copper pipe is hot and the thick one very cold(when tipping your finger on your tongue and pressing it against the pipe your finger should stick a bit) if all checks out then it's the thermostat switching the compressor off at the rong temp.
Personal opinion in this case I believe it's a blocked dryer or gas leakage.
Regards
Jun 09, 2016 | Samsung Refrigerators
Ruud UAKA-030JAZ fan spins, not blowing cold air
there are 3 things to be considered,first,if the compressor motor `s connectors are having loose,it gives a hi ampere to your RELAY that can cause to its contacts being fried,second,the compressor motor itself is gaining a hi ampere already i.e. having unusual sound that can cause heavy friction inside the turning mechanism and third the last but not the least,maybe this time,the tubes or the compressor itself having very small holes that causes to the refrigerant to escape and it doesn`t gives off cold air.
Apr 17, 2014 | Ruud Heating & Cooling
Refrigerator compressor won't run
Plug it in. It may be in Defrost cycle, nothing runs when in defrost cycle. Amana's are famous for defrost terminators to go bad. The fan in the back should be running even if the compressor is bad. Do you hear a clicking in the compressor? If so the overload in the compressor is bad.
Jul 28, 2013 | Refrigerators
Westinghouse Fridge/freezer RJ340M. Not freezing cold.
Could be several problems, it may have a leak in the coolant system, the compressor may be bad, or the control system may be malfunctioning.
Mar 17, 2013 | Refrigerators
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
04 Saturn vue compressor turns off when fan is set to 3 or 4
The problem is the blower motor speed control resistor, it is located near the blower motor in the housing. I exchanged mine and it works like a charm now.
May 31, 2012 | 2002 Saturn VUE
COMPRESSER IS VERY HOT, FAN OUTSIDE BLOWING COLD AIR OUT NOT HOT
Most likely the unit is low on refrigerant. You could also have a restriction in the system. You need to put gauges on the unit.
Jun 14, 2009 | Ruud UBHC Air Conditioner
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
A/C FAN NOT WORKING
I presume you are talking about the blower motor and not the cooling fan on the engine?
If you have checked the fuse then ensure there is power at the blower motor when switched on.
Jul 22, 2008 | 2005 Jeep Wrangler
Whirlpool gold side by side refrigerator relay compressor?
turn it off for an hour or so and give the coils time to thaw just in case they somehow froze up. also if the frig was tilted in the wrong direction (which it doesnt sound like it was since it has food in it!!!) it could need time to let the refrigerant and oil settle back into the compressor.
where are you located (cold or warm climate)?
and where is the frig located (in your home)?
Jan 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Heating & Cooling Logo
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
