Question about Electrolux EOB5630 Ultrafan Electric Single Oven
Our electrolux eob5630 oven keeps turning off
It seems to get to the required temperature and then switches off, we have to wait for it to cool down and it will then work, does any one have any ideas, we wandered if it was the thermostat and if so how hard are they to replace?
Thanks
Its the thermal cut out. replace it. ISOLATE oven.
slide oven out a few inches, remove knobs, remove front panel(two screws)
you will only be able to pull panel 3-4" due to wires.
Cutout has 2 blue and 2 white wires..
you may need to snip a couple of cable ties.
Put new cutout in one wire at time( easy to forget where they go)
Tidy up wires. Put cover back. Secure oven in hole.
Turn on power. Reset clock(otherwise won't work)
Done 10 minute job
Posted on Sep 03, 2009
I have a eob6630 Electrolux cooker. Top element / bottom and work ok. But oven cuts out approx 20 mins when cookin. Then switches off. But comes back on when cools. Approx 20 mins. Can anyone advise about...
From my experience the most common reason for this failure is a thermal switch for cooling fan. It is located on the upper side between the wiring and its function is to switch off the cooling fan when the temperature drops even though the oven is already turned off. If the cooling fan does not work then it will increase the temperature on the cabinet and the main temperature limiter will switch off the oven.
Dado
Jul 01, 2014 | Electrolux Ovens
I have a faure oven which is in safe mode . How do I get it to function.
press and hold the temperature button and simultaneously hold the 'temperature duree' knob to the + or - position until you hear a beep. This locks and un-locks the child safe mode
Jul 29, 2011 | Electrolux EOB5630 Ultrafan Electric...
What is the diference between an EOB5630, and EOB5630B, an EOB5630x etc. I have an EOB5630 oven fan element to replace but need to be sure I get the right one. Are these models interchangeable??
I would guess they are the same element in Australia the last letter in electrolux ranges signifies the color or type of clock fitted the B would be for Black ovens the X would be a multi function oven they all have the same fan element
May 29, 2011 | Electrolux EOB5630 Ultrafan Electric...
Eob5630w oven shutting down before set temp isreaced aprox 198c also cooling fan not comingon
The reason the oven is shutting down is because it is overheating due to the cooling fan not working, and a safety thermostat is turning the oven off.
You need to repair or replace the exterior cooling fan.
Jan 05, 2011 | Electrolux EOB5630 Ultrafan Electric...
Using my EOB5630 oven went bang
the fan element will have shorted out. if you remove the panel from inside the oven you may see where the circular fan has shorted. It will have blown a fuse poss in a plug if connected that way.or tripped a circuit breaker. remember to set the clock when power is restored as it wont work until you do.
Jul 29, 2010 | Electrolux EOB5630 Ultrafan Electric...
Electrolux EOB5630 door hinge locked closed
Look for a release button. If not, it may have a locking mechanism that needs to be released. Try some of these: push the hinge to one side while lifting, press the hinge down then lift, pull up on the hinge while pulling. Good luck!
Oct 24, 2008 | Electrolux EOB5630 Ultrafan Electric...
Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
May 15, 2008 | Electrolux EOB5630 Ultrafan Electric...
Electrolux cooler fan
absolutely, Never registers when the oven is below a certain temp to shut the fan off. It always thinks it's too hot and the fan will continue to run
Nov 21, 2007 | Electrolux EOB5630 Ultrafan Electric...
Upper cooling fan constantly running
not sure of location but either on roof of oven or at the back close to the fan, but there is a fan start stat that turns the cooling fan on and off. could be stuck in on mode. only cure is to replace
Jun 12, 2007 | Electrolux EOB5630 Ultrafan Electric...
Electrolux EOB5630 Ultrafan Electric Single Oven Logo
1,271 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
