Question about RCA DRC8060N DVD Recorder
New discs reported as bad discs
RCA DRC 8052NC DVD recorder reports new discs as bad discs. It has been recording from scheduled events just fine. Now it doesn't recognize new discs as valid to record to. I purchased another set of discs just to make sure i didn't have a bad batch of discs. Same problem. This unit was sent in 6 months or so ago with an inability to read any discs at all. Will this problem be related and will I again have to send it out for repairs?
  • rlerario Nov 15, 2008
    this DVD Recorder has an internal hard drive (disc library) and on ours, when the disc library starts to get filled, it records, but doesn't recognize that it has recorded. It doesn't recognize new disks (cannot use DVR-R, but will use DVR+RW and DVR+R). You can temporarily fix it by initializing again and erasing the entire disc library.
  • 4,102 Answers
It sounds like it could be the start of the same problem have you tried using a lense cleaning disk to clean off any dust are you making sure the air vents arent blocked on the unit as overheating can cause this problem but first try lense cleaner and if the air vents are not blocked then you will find it is the same prob as before they are known for this fault and i have came across several that need replacing at the end of the day you need to think is it worth keep getting repaired paying out for this all the time or would you be better of buying a new one as it is the second time it has played up i would replace whole unit as this problem looks like it will keep happening hope this is some help to you good luck
Posted on Nov 19, 2007
I have rca drc6300n i am trying to record vcr on to dvd when i install the blank dvd r it comes up disc error tryed several disc (new)
Try to play a dvd in the recorder.If it plays the DVD, most likely the recorder is fine If not, the lens is dirty or the recorder has a problem.You can also try a different brand of DVD/rw
Nov 23, 2014 | RCA Audio Players & Recorders
I have a rca drc 8295 and have old family movies on vhs and want to record to dvd. what dvd do i need dvd r?
Use the DVD+R Disc better for transfering recording.Read ur DVD Recoder/VCR combo owner manual,before u do this,for the correctly setting to do transfering recording.
Jun 23, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
MY RCA DRC 8320n DVD Recorder/VCR Combo will not accept tapes. DVD works fine. RCA help line is a joke. I will never buy another RCA product.
Yah, you're going to be taking that in for repair. I worked for couple of years at RCA / Sony / Panasonic / ... and 60 more names - service center. When a VHS Cassette loading mechanism doesn't work - it probably needs loading motor or loading gear, something repaired. At the cost of DVD and VHS combos these days I'd call it Not Worth Repair (NWR) out of the starting gate. At least $50 an hour, at least 2 hours ... that's beyond the cost of a new one.
Nov 22, 2009 | RCA DRC8320 DVD Recorder/VCR
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
RCA DRC 8052NB will not read discs
This sound like a problem with the laser read circuits and it may be solved with a simple cleaning and using compressed air to clear the unit of debris .To do this you must take off the top cover of your unit by taking out the screws and lifting the top off. To clean the laser head you should use cotton swabs and isopropyl alcohol. put a small amount on the cotton swab and rub the swab gently back and forth over the head, until it seems bright and shiny.Check the transport carriage for dust and debris and also the gears. all these must be clean for proper operation. You may want to put a little lithium grease on the gears and guide rails for smooth operation. All this should be done in minute amounts so you do not over do it and cause more problems. If all this fails to allow you to use you disc player, Then you probably have a worn out laser sensor and will have to have it replaced. If under warranty send it in and if not try to find the part number and order it and either take in to a service center for repairs or do it yourself. Hope this helps you with your problem.
May 15, 2009 | RCA DRC8052N DVD Recorder
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Model DRC 8310 RCA VCR/DVD player/recorder combo.
Did you put a splitter onto the cable signal? If yes, the signal is attenuated to much and there simply isn't enough signal for the recorder to decode. Call your cable company and request a signal amplifier be placed on your line. It's usually free.
Mar 15, 2008 | Televison & Video
Recording a TV program on a Panasonic DVD Player/Recorder
DMR ES 10 does not record on R + disc . change to R - disc and try
Oct 03, 2007 | Panasonic DMR-ES10 DVD Recorder
Recording a movie that I have on my pc to a disc useing a RCA DRC8335
if you have an s video out as well as audio out on your laptop connect it to svideo and corrasponding audio input on dvd recorder. hook up recorder to a TV to see the movie your transfering then press record on drc that should be good luck
Sep 01, 2007 | RCA DRC8335
RCA DRC8060N DVD Recorder Logo
138 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
