Question about Alpine CDA-9885 CD Player
No remote on VDO CD 139 CD player
Hie
I recently bought a VDO CD 139 CD player and am trying to connect it to the amp for the sub but it doesnt have remote wire outlet from head unit. It has sub out lines and 2 other lines for phone. How do I manage to connect the remote wire for amp to turn on the amp?
Ralph
  • 78 Answers
If the head unit does not have a 12v switched output you could connect it to the cars ignition which means that the amp will switch on when you turn the ignition on and it won't drain the power when you switch off
Posted on Nov 21, 2007
On alpine cd3 9852 model, attached wiring for model of car and proper connections, yet subs only work for radio.subs will not work for CD or IPod connection.all wiring is color coated and has been checked...
Make sure you are using the blue/white wire to turn the amp on. The blue wire is antenna remote and turns off when leaving tuner mode. The blue/white wire is amp remote turn on.
Sep 15, 2011 | Alpine CDE-9852 CD Player
Kenwood eXcelon radio problem I have 2 subs in my civic that work perfectly fine but i recently tried to add another amp to run my front door speakers seperately. I spliced the remote wire between the two...
Cut the remote wire from the radio.
install a relay in line
the relay will have 4 or 5 terminals
connect terminal 87 to battery power and fuse it at 3amps
connect terminal 86 to the remote output from the head unit
connect terminal 85 to ground
connect terminal 30 to your amp turn on wires
this allows the turn on load to run thru the relay and not directly off the radio remote output
Nov 25, 2017 | Kenwood Kdc-x494 Car CD/ MP3 Player
I have a kenwood kdc 139 and there is no bass at all, the bass only kicks in when i change the balance to fully left or fully right.
Check your wires to make sure they're not crossed. follow them all the way back to the radio if you have to. when it comes to subs, you have to get it right with how you connect your possitive and negative especially coming out of the amp. if you have rca's connected from the radio to the amp, then check the output to your subs from the amp to the subs, make sure theyre wired correctly. if you used your stereo wires for input to your amp, then make sure those wires are positive with positive and negative with negative. also make sure you have them hooked up to rear output only. don't use one rear and one front.
Apr 05, 2010 | Kenwood KDC-135 CD Player
Is there a wiring diagram for the nikkai EAPA450 Amp
Hi, if you still need a photocopy of instructions email me mail@srands.co.uk
If you want instructions in brief this involves POWER CONNECTIONS, PHONO LEAD & SPEAKER CONNECTIONS:
POWER (At the same time when routing these wires, I would connect the PHONO LEADS from the car cd player to the amp, if your car cd player only has 1 preout (1red & 1 white) then you will need two phono splitters, a female to 2 males. Phono leads carry the unamplified sound from cd player to the amp):
~ Permanent 12V+ (Thick lead that is fused direct from battery all the way to the amp, wire must be 20a to 30a +, hence 1cm diameter wire, known as AWG8, Maplin sell cheaper kits then most)
~ Amp REMOTE (A thin insulated cable (5a is OK) from car cd player amp remote wire, this turns the amp on when the cd player is on, if your car doesn't have an amp remote wire, suggest nearest ignition supply or seperate switch that you turn on when you want to turn on the amp)
~ GrouND 12V- (Insulated lead (20a to 30a) to nearest part of unpainted car chassis such as interior panel screw hole, instead of an insulated cable all the way from the batery, this is common practise.
SPEAKER:
Each speaker has a - negative & + positive, these must connected correctly. The amp has 4 channel, 2 channel labeled as front, 2 channels labeled as rear. Using speaker wire, connect cable from amp to speakers. Note: Ensure the speakers being connected only receive sound from the amp (Not cd player as well, as would damage players or at the very least impair sound)
The amp has a feature called bridgeable this means a sub 8" or 10" sub can be powered by 'bridging' two channels. For example there are 2 ways to bridge power a Sub on the NIKKAI EAPA450:
i) Sub speaker wire positive + to channel RL and Sub speaker wire negative - to channel RR.
OR
ii) Sub speaker wire positive + to channel FL and Sub speaker wire negative - to channel FR.
Switches:
~ Bass boost, meant to be on for a channel if using sub, otherwise off.
~ X-over mode adjust hi/lo frequencies, only work if both x-over switches are on! Then adjust switch frequency knob, until it sounds right.
~ Gain (Volume knob) adjust volume knob up or down, until it sounds right!
NOTE:
You will need patience! many hand tools and parts such as: Wiring kit, fuse holder 20a/30a, Phono leads, speaker cable, Fork/ring connectors, wire strippers, wire cutters, set of screw drivers, also ueful to have zip ties to tdy excess cable and 'P' cable clips to tidy speaker wire to shelf, etc.
OK
Any more questions just email me mail@srands.co.uk
Dec 01, 2009 | Car Audio & Video
Subwoofer Help
check the amp. the "switches" gain,bass boost...etc they might be over powering your subs and heating them up. if those are fine then you mite want to try your subs on another amp...it migt just be that the subs are easily over heating.
Aug 26, 2009 | Rockford Fosgate Car Audio & Video
Hello i just recently bought alpine speakers for my eclipse 2003
mostly because the subs in the back are probley using more amps than the ones in the front in the front should be used mostly for vocals and your bass in the trun so maybe trying to unhook the ones in the front from the sub and just leave then hooked up to the cd player where you can hear the vocals really good and leave your subs in the back hooked up to the amp
Jul 27, 2009 | Alpine SWS-1223D Car Speaker
I had an amplifier and sub installed using the factory cd player and it worked fine. then i replaced the cd player and now the sub and amp are not working but the new headunit works fine. the amp is...
if the wire ur talking bout suppose to be connected then ur radio shouldn't *** on ..the wire suppose to connect to the back of the radio where a screw goes, its a ground wire...hop i was of help.
Jul 12, 2009 | Kenwood KDC-MP435U CD Player
Cd player plays, but no sound comes out of speakers.
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Jan 31, 2009 | Kenwood KDC-MP238 CD Player
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Kenwood KDC-MP228 CD Player
I have a jvc KD-G320 cd player and i am trying to hook it up to my 2 12" subs n the cd player doesnt seem to b sending the message to the subs to kick is there anything special i have to get to make...
ok first make sure all the leads are good
remote
and rca leads
check power to amp
then go in to settings in the head unit and change from rear to woofer and then do sub contol on high
Aug 16, 2008 | JVC Car Audio & Video
Alpine CDA-9885 CD Player Logo
304 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
