Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
Our A O Smith pump/motor gets airbound everyday
Our A O Smith jacuzzi 10 amp, 115V pump/motor gets airbound everyday and has to be primed everyday. How can I solve this problem.
  • 22 Answers
Well somehow air is obviously getting into the pump line. Easiest fix is to move the pump below the water level of the tub and then gravity will keep water in there. If you do have the pump below the water level, then make sure you don't have jets shooting a bunch of air directly at the intake in the tub. If that's not the case and it is below water level, then make sure you don't have a leak in the line somewhere.
Posted on Jul 19, 2009
The pump is ceased how to I get it off the motor
if motor was running hot probably ruined seals or pump housing replace whole unit less hassle
Oct 09, 2013 | AO Smith A O Smith Motors Century 1hp 115v...
How to wire the 115v/230v magnetek pool pump motor (1.5 Hp wth sq flange, 56Y) for 115V ?
if you are not a motor service person do not try this your self get the right help be safe
Sep 23, 2013 | AO Smith 1.5hp 1800RPM 56 Frame Farm Duty...
What are wire colors on A O Smith UST1102 ?
115v motors are wired with Black (hot) White (neutral) and Green (ground)
Rod
www.uspartscenter.com
Jan 21, 2013 | AO Smith A O Smith Motors Century 1hp 115v...
I just installed Hayward 1.5HP inground and it tells me that if i use the 115v to use a 30 amp breaker - and when i left the 230V button positioning inside the back of the pump and connected with a 14 ...
double the amps, 230 runs cooler (my fav) . 1.5 is 9.6 amps at 230 volt. you will need to set the motor to run on on the lower voltage this is why you are having problems.. also the motor is thermally protected . this why it will run for awhile and shot off .. remember to prime the pump after any pump repair !!!! . jay the pool pump repair guy in longwood florida
Jun 05, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
I bought a red lion sprinkler pump with an A O Smith 1.5HP electric motor on it. A O Smith model # CET50ABH, serial # 27308J2. I knew I would have to wire it (115/230v capable) and I want to go the 115v...
Your black and white wires go on L1 and L2. It will not matter which wire goes on with line terminal as long as you just put one cord wire on L1 and one on L2. Be sure you properly switch the motor to run on 115V since it will facotry prepped for 230.<br /> <br /> John
Aug 18, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
My pump will not come on.
Download the AO Smith Motor Troubleshooting Guide below (a.k.a #3400 from aosmithmotors.com) below:
http://www.aosmithmotors.com/WorkArea/DownloadAsset.aspx?id=588
Jun 29, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
USQ1102 pump gets power, buzzes, trips breaker
The motor-start capacitor is bad. This is a very common problem. It can be easily and cheaply fixed by replacing the capacitor. Replacements are usually less than $10.
See http://www.youtube.com/watch?v=ZEIv5ClLqXg for a step=by=step guide.
When you have the capacitor in hand, check the model# which is printed on it. Alternatively, you can Google the motor brand & model to find the parts list which will identify the right one. Then Google the part number, to find a seller.
Jun 27, 2009 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Dec 13, 2008 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
135 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
