Question about Electric Lawn Mower
Electric lawn mower tripped the circuit breaker.
I have an electric mower which half way through a job slowly stopped working. I looked around and found the circuit breaker was tripped. I thought it might have overheated so I stopped it for the day. The next day I tried again and it started but quickly stopped and tripped the breaker again. Any advice would be appreciated.
  • 227 Answers
I suggest you check under the mower to see if grass has built up on the under side of the deck. this will cause a drag on the blade that is transfered to the motor and will cause it to pop the breaker. Cleaning the deck should fix it. Good Luck!
Posted on Jul 19, 2009
    President:
  • 1,486 Answers
Motor brushes worn out.Change them.
Lawn mower batter charger blows circuit breaker
I'd try plugging it into another outlet first, then try turning off any other appliances that might be on that same circuit. If it continues to trip the breaker, I'd take it to the small engine shop.
hope this helps
Apr 19, 2014 | Toro Garden
Part way through a mowing my electric mower trips breakers deck is clean
motor is probably drawing to many amps and overheating have to change voltage regulator
May 22, 2013 | Garden
I have an earthwise 12 amp electric lawnmower that trip the circuit breaker and now will not start at all. Any suggestions on what might be wrong and how I could fix it
If the circuit breaker trips there are three possible reasons
1. the motor is being overloaded - clean underneath ( as recommended above); or if the grass is too wet or too long or both you may need to handcut; or the motor bearings need lubricating (same problem as me-how?)
2. There is an electrical fault - check the plug and cord (as above) or get an electrician to check the motor and connections; or the carbon brushes to the motor need replacing
3. You have a faulty circuit breaker! - borrow and test with a replacement
Apr 11, 2012 | Electric Lawn Mower
Electric lawnmower trips circuit breaker as it gets up to speed
Hi Dogtown,
Cool name. Been there. Went to a heavier gauge extention cord and made sure nothing else heavy was on the same circuit.
Problem disappeared.
Best regards
Aug 14, 2010 | Electric Lawn Mower
Replaced switch but circuit breaker trips on start up ! Mowermm600
Your circuit breaker will trip because of two main reasons:
  • Electrical power point circuit is overloaded (too many appliances active on the same power point circuit)
  • Power Lawn mower has become unsafe as your active live is able to reach your earth connection (e.g. short-circuit). Make sure that you have correctly reconnect ALL your power leads wires (check that the Active and Neutral wires have not been transpose). With power off/device unplug, use a multimeter on resistance range and verify that your active lead pin is not showing a reading against the Earth (middle) pin when the mower switch is turn on or off! There should not be any resistance reading between the Earth and Neutral (opposite pin to Active) pins either!
Hope it helps.
Aug 01, 2010 | Black & Decker Garden
Electric lawn mower repeatedly trips house circuit breaker
The breaker is tripping because there is a short in the mower electrical circuit -- most likely in the motor winding -- it overheated.
If you have a multimeter measure the resistance (ohms) of the motor winding by putting the meter probes on the two flat prongs of the power cord with the mower switch on. If you get near zero ohms, the winding is shorted -- motor "burned up".
Using the multimeter again, check for continuity between the round ground pin on the power cord and each of the two flat prongs. If you get continuity on either of these, there is a short to the mower chassis. This can probably be corrected without much expense.
My bet is on the motor winding being shorted.
Charlie
Aug 20, 2009 | Craftsman Garden
Dryer trips circuit breaker smell almost like something burning coming from dryer
In order to trip a circuit breaker, there is almost for sure, a dead short to ground. Takes quite a bit to trip a breaker. The smell is most likely something electrical burning. Stop resetting the breaker and have it checked out. Continous resetting and tripping can cause more damage. The breaker is doing it's job.
Jul 30, 2009 | GE DVLR223 Dryers
Electric lawn mower slowed down then stopped working?
The carbon brushes on your mower have worn and, need to be replaced; order them from black & decker
May 21, 2009 | Black & Decker 19" Electric Lawnhog...
Electric lawn mower will not start
check the speed controller and also check the terminals on the motor.
May 21, 2009 | Electric Lawn Mower
My electric lawn mower starts briefly and then trips the circuit
check cord from plug to the electric motor.if it has a reset or breaker check for damage. if no obvious damage problem is electric motor.may be cheaper to buy new 1
May 06, 2009 | Electric Lawn Mower
Electric Lawn Mower Logo
1,864 people viewed this question
Top Electric Garden Experts
Steve Oakes
Mike Squire
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
