Question about LG ALLTEL AX275 Cellular Phone
My phone does a similiar thing
When i1m texting and go to add a symbol i push 4 and it goes to t9 word and puts an i also it freezes when i do that!
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
How to turn t9 off on a moto razr??
Selecting a Text Entry Mode
Multiple text entry modes make it easy for you to enter
names, numbers, and messages. The mode you select
remains active until you select another mode.
Press # in a text entry screen to select one of the
following entry modes:
Primary Your primary text entry mode .
Numeric Enter numbers only .
Symbol Enter symbols only .
Secondary Your secondary text entry mode .
Jul 13, 2010 | Motorola Mobility RAZR V3
How do i get the t9 off my text messages on a samsung d900???
ABC, T9, Number, and Symbol modes
You can enter text in some features such as Messages,
Phonebook, or Calendar, using ABC mode, T9 mode,
Number mode, and Symbol mode.
Changing the text input mode
• Press the right soft key to change the text input
mode.
• Press and hold [ ] to switch to Number mode.
• Press and hold [ ] to switch to Symbol mode.
Using ABC mode
Press the appropriate key until the character you want
appears on the screen.
: ABC mode : T9 mode
: Number mode : Symbol mode
Apr 07, 2010 | Samsung SGH-D900 Cellular Phone
How do i insert symbols while texting ... I can text but cannt insert ?,=? + £
Here's how:
Enter text
When entering text, you can change the text input
mode:
• Press and hold [ ] to switch between T9 and
ABC modes.
• Press [ ] to change case or switch to Number
mode.
Enter text in one of the following modes:
Mode Function
ABC
Press the appropriate alphanumeric key until
the character you want appears on the
display.
T9
1. Press the appropriate alphanumeric
keys to enter an entire word.
2. When the word displays correctly, press
[ ] to insert a space. If the correct word
does not display, select an alternate
word from the list that appears.
Number Press the appropriate alphanumeric key to
enter a number.
Symbol Press the appropriate alphanumeric key to
select a symbol.
Here is a link for a free online user's manual for your convenience:
http://downloadcenter.samsung.com/content/UM/200904/20090420115654593/CMS_-_Samsung_B2100_UM_EU_Eng_FINAL_Rev.1.1_090326.pdf
Please leave us 4 thumbs up :)
Nov 29, 2009 | Samsung Solid B2100 Cell Phone
How do you take t9 off phone
Hi!
I have a D900i & the way to change from T9 in a text message is to press the button on the top right hand side. It looks like 3 dots, one on top of the other. You can use this button to switch between T9, Symbols, Numbers & manual spell modes.
There's no way of removing T9 all together but your phone should remember your preference & default to manual spell each time you need to type something.
Hope this helps!
Nov 16, 2009 | Samsung SGH-D900 Cellular Phone
I cannot figure out how to get my phone off all caps for texting
While on the message editor, press 0 to switch from lower to upper case and vice versa.
Oct 09, 2009 | Motorola Mobility TracFone C139-4 Cellular...
How do i put in underscores in my Samsung SGH-F330?
you should be able to repeatedly press the 0,1,# or * keys, to input your symbols.....provided your phone is not set to predictive text.....or T9.......or auto-tet, or sure-type, or whatever its called.....if it is, then while you're typing a text, press your options or menu key, and you should see a "symbols" option or something along those lines. hope this helps.
Sep 21, 2009 | Lands Phones
Texting and taking off the t9 feature of assuming what im going to type
sometimes it will pop extra words up like that for me, but i found that if you just ignore it and keep typing, they will go away. try it :)
Aug 18, 2008 | LG Shine KE970 Cellular Phone
The text dictionary keeps giving me the wrong words and i cant change, how do you knock it off. the phones a samsung d900i
Using T9 mode
T9 is a predictive text input mode that allows you to
key in any character using single keystrokes.
Entering a word in T9 mode
1. Press [2] to [9] to start entering a word. Press
each key once for each letter.
For example, press [4], [3], [5], [5], and [6] to
enter HELLO in T9 mode.
T9 predicts the word that you are typing, and it
may change with each key that you press.
2. Enter the whole word before editing or deleting
characters.
3. When the word displays correctly, go to step 4.
Otherwise, press [0] to display alternative word
choices for the keys that you have pressed.
For example, OF and ME use [6] and [3].
4. Press [ ] to insert a space and enter the next
word.
Other T9 mode operations
• Press [1] to enter periods or apostrophes
automatically.
• Press [ ] to change case. Lower case (No
indicator), Initial capital ( ), and Capital lock ( )
are available.
• Press [ ] to insert a space.
• Press the Navigation keys to move the cursor.
• Press [C] to delete characters one by one. Press
and hold [C] to clear the display.
Adding a new word to the T9 dictionary
This feature may not be available for some languages.
1. Enter the word that you want to add.
2. Press [0] to display alternative words for your key
presses. When there are no more alternative
words, Spell displays on the bottom line.
3. Press <Spell>.
4. Enter the word you want using ABC mode and
press <OK>.
"The faulty interface lies between the chair and the keyboard"
Apr 21, 2008 | Sony Ericsson w580i Cellular Phone
Reset Symbol Recognition?
This happens because you have your enV text entry mode set to "Word". Undoubtedly, you did this for the same reason I did - to get T9 mode working when you text from the front keypad with the phone CLOSED, instead of from the QWERTY keyboard with the phone OPEN.
If you go to Messages->Settings->ALL Msg->Entry Mode and set it to Abc instead of Word, your problem should go away.
Mar 29, 2008 | LG enV VX9900 Cellular Phone
LG ALLTEL AX275 Cellular Phone Logo
26 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
