Question about Kenmore Elite 45986 Front Load Washer
"Shock Absorber" wear?
How do you know if the "shock absorbers" are in good shape or wearing out?
My wife is concerned that our 3 yr. old Kenmore Elite Smartwash Quietpak9 HE4t has been making progressively more noise during the rinse and spin cycles. It is on a level ceramic tile floor, on top of the matching base that raises it about a foot. I removed the front panel of the base, all ok there exept for some dust bunnies. I removed the front bottom panel of the machine that is held on with three t20 screws, to expose the motor compartment. All seems to be in good order. There are two large gauge springs, one on either side of the tub, which hold the tub up to the top of the frame. the bottom of the tub is supported by four shock absorber-type struts. They all seem to be connected properly, but I have no idea how to test if they still provide the proper amount of resistance.
Any clues?
Thanks for any advice.
  • 1 more comment
  • Ed Trembicki-Guy Jul 19, 2009
    Some add'l info:
    The noise is at the start and end of the spin cycle, as it's speeding up and slowing down, but stops once it reaches a certain speed. The noise is a sort of clunking sound.
    Thanks Stan. After giving it a careful listen, I think it might be some other component. It's a clunk-clunk-clunk sound when it begins to spin up and just as it's coming to a stop. Once it hits a certain RPM threshhold, the clunking stops. One other thing I noticed when I had it open: sitting in the back left corner was a black (rubber ?) rectangle, about 5"x6"x3/16", and one side was somewhat sticky. Not sure if that's where it's supposed to be, or if it fell off some other spot.
  • Ed Trembicki-Guy Sep 12, 2009
    I finally got around to pulling the washing machine out and removing the back panel. It does have a motor and pulley. The pulley is fastened tightly, there is not play. The belt has very little deflection, probably less than 1/2", so I don't think it's that either. I don't see the obvious place to re-locate the two vibration dampers that are sitting on the bottom of the machine. Should one be stuck in the center of the back panel that I removed? The other one was near the front, on the right side. I'm not sure if it belongs somewhere on the right wall, or if it belongs on the front wall and just fell down to the right. I'll see if Kenmore has any diagrams, but any suggestions are appreciated.
    Thanks,
    Ed
    Novelist:
  • 108 Answers
A lot of people convince themselves that the shock absorbers are causing the problem, but that is rarely the case. if you remove one of them, you will find that they are actually two pieces, and only provide some compression cushioning as the barrel moves around. a little bit of grease might help them a little. Do make sure that they are all connected and positively secured in place, as they sometimes look connected correctly but actually aren't, which can cause problems.
In my experience the problem is that the base, over time, begins to amplify the vibrations of the machine. It is after all, a top-heavy setup. Try putting the machine directly on the floor and see if that does the trick (get help, it's heavy)
Posted on Jul 19, 2009
Testimonial: "Excellent suggestions."
  • StanStihl Jul 22, 2009
    The black rectangle is a vibration dampener that is supposed to be stuck to the interior wall, I believe. I was thinking... I cant remember if that model uses a motor and pulley setup to drive the drum, but if it does, you might want to check and see if the large pulley is completely tight... granted, you will have to go in through the back of the machine for this, but it couldn't hurt.
  • StanStihl Sep 14, 2009
    Well, it's funny... I went to a house about a week ago with a virtually the same problem, which apparently the previous two technicians that had been called were unable to locate. After taking the front panel off, I put the machine into spin (with a generous load of wet clothing to replicate the situation exactly) and watched the interior with a flashlight. It turned out to be a plastic vent for the steam which had come unsecured from the vent outlet, and would begin to whack the back of the machine during spin. I don't know if the Kenmore has the same plastic vent, but it could definitely be a hose from the drain pump, or something like that.
    The fact that it only makes noise as the machine approaches full spin speed, but then goes away at least makes me think it is something similar. The barrel tends to wobble more as it is changing speed.
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: he4t kenmore elite smartwash quietpak9. keeps flashing F2?
"F02" is a Long Drain error. This is an indication that there's an obstruction somewhere in the drainage system. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the bottom front edge of the lower toe panel directly below the door. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Posted on Mar 02, 2010
What othernshocks will fit on a 2002 chevy avalanch 2 wheel drive?
These, and they must be for right model
2002 Chevrolet Avalanche 1500 Shock Absorber
  • 02 2002 Chevrolet Avalanche 1500 Shock Absorber ... www.partsgeek.com/catalog/2002/chevrolet/avalanche_1500/suspension/...
    • 4.8/5
    • 52 REVIEWS
    Buy a 2002 Chevrolet Avalanche 1500 Shock Absorber at discount prices. Choose top quality brands AC Delco, Arnott, Bilstein, Fox Shox, KYB, Monroe, OSC Automotive ...
  • 02 2002 Chevrolet Avalanche 2500 Shock Absorber ... www.partsgeek.com/.../2002/chevrolet/avalanche.../shock_absorber.html
    • 5/5
    • 45 REVIEWS
    Buy a 2002 Chevrolet Avalanche 2500 Shock Absorber at discount prices. ... Comes in three forms of Monotube Shock Absorbers, ... • 2002 Chevrolet Avalanche 2500: ...
  • Related searches for 2002 chevy avalanche shock absorbers
  • 2002 Chevy Avalanche Performance Shocks & Struts - CARiD www.carid.com > ... > Performance Shocks & Struts > Chevy > Avalanche Chevy Avalanche 2002, 4600 Series Standard 46mm Monotube Shock Absorber for Stock Height Vehicles by Bilstein®, 1 per Pack. Finish: Yellow Paint.
  • 2002 Chevrolet Avalanche 2500 Shock Absorber and Strut ... www.autopartswarehouse.com > ... > Shock Absorber and Strut Assembly We have the Largest Selection of Shock Absorber and Strut Assembly for your 2002 Chevrolet Avalanche 2500. Get yours at Wholesale Prices here at AutoPartsWarehouse!
  • 2002 Chevrolet Avalanche 1500 Shock Absorber and Strut ... www.autopartswarehouse.com > ... > Shock Absorber and Strut Assembly We have the Largest Selection of Shock Absorber and Strut ... Shock Absorber and Strut Assembly 2002. Shock Absorber and Strut Assembly for 2002 Chevrolet Avalanche ...
  • 2002 Chevy Avalanche Performance Suspension ' Shocks ... www.carid.com > ... > Suspension Systems > Chevy > Avalanche Bilstein 4600 Series Shock Absorbers and Struts are designed ... Chevy Avalanche 2002, ES Series Shock Absorber by ... 2002 Chevy Avalanche Performance Suspension ...
  • 2002 Chevrolet Avalanche 1500 Shocks & Struts - JCWhitney www.jcwhitney.com > Suspension & Chassis Looking for Shocks & Struts for your 2002 Chevrolet Avalanche 1500? ... 2002 Chevrolet Avalanche 1500 Shocks & Struts ... MONOMAX SHOCK ABSORBERS ...
  • 2002 avalanche shocks ' eBay www.ebay.com > Search > 2002 avalanche shocks Find great deals on eBay for 2002 avalanche shocks 2002 ... Ultima Strut Shock Absorber Full Set Chevy Surburban ... KYB Gas-A-Just Shock Absorbers (Fits: 2002 ...
  • Chevy Avalanche Struts - Best Shock Absorbers & Coilover ... www.autoanything.com/suspension-systems/Chevy/Avalanche/... ... Reviewed for a 2002 Chevy Avalanche -4/26/2016 10:06 PM. After researching various brands of shock, ... Chevy Avalanche Shocks & Struts are Available for ...
  • Jun 10, 2016 | Cars & Trucks
    My van shimies left and right badly....and it pulls to the left....it does it more when going straight and not so much when going around curves
    check the vans rear shock absorbers if they are faulty the car can exhibit this type of behaviour and braking will be less efficient. Also tyre wear will be affected to.
    I am not a shock absorber expert but had recently my four shock absorbers replaced as the fluid had ruptured in the front shockers and the rear mounts for the rear shockers were corroded and unsafe. (shock absorber expert at repair place mentioned the symptoms you are describing as a rear shock problem or the rear leaf springs are faulty)
    Mar 18, 2015 | Cars & Trucks
    My 2006 Fatboy front end vibrates above 60mph
    Hi Anonymous, and the usual suspects are:
    1. Improperly loaded motorcycle. Non standard equipment on the front end such asheavy radio receivers, extra lightning equipment or luggage tends to cause unstable handling.
    2. Incorrect air suspension pressure.
    3. Damaged tire(s) or improper front-rear tire combination
    4. Irregular or peaked front tire tread wear.
    5. Incorrect tire pressure.
    6. Shock absorber not functioning normally.
    7. Loose wheel axle nuts.
    8. Excessive wheel hub bearing play.
    9. Improper vehicle alignment.
    10.Steering head bearings improperly adjusted.
    11. Tire and wheel unbalanced.
    12. Rims and tires out of round or eccentric with hub.
    13. Rims and tires out-of-true sideways.
    14. Shock absorber improperly adjusted.
    15. Worn engine stabilizer links.
    16. Damaged rear engine isolation mounts.
    17. Swing arm pivot shaft nut improperly tightened or assembled.
    Good luck and have nice day
    Dec 28, 2012 | 2006 Harley Davidson FLSTF Fat Boy
    Low speed wobble 3 wheel harley
    Hi Mark, and the usual suspects are:
    Nov 22, 2012 | Harley Davidson FLSTC Heritage Softail...
    High speed wobble
    Sep 29, 2012 | 2011 Harley Davidson FXDWG Dyna Wide Glide
    2001 flstc front end low speed woble
    Mar 13, 2012 | Harley Davidson FLSTC Heritage Softail...
    My cadillac devail Shaking while driving som of the tim
    have the tires checked asap, also it might have some front end linkage wear .. you can check the tires yourself by jacking the car and checking them one at a time and spinning it and checking it to be round.. cady shocks are costly and the tires must be in good shape to stop excessive wear and a out of round tire will destroy a shock absorber in no time flat..you can take it to several tire shops and ask for a estimate ..jay the pool motor repair guy florida .. did you vote for your favorite fixya guy ?
    Feb 09, 2012 | 1997 Cadillac DeVille
    Kenmore 417.43042200 Front load washer. Replace shock absorbers and coin trap
    Hello Karen,
    The following video should fully explain everything that you should know on how to do this replacement and any warnings.
    Good Luck!
    Rich Lilja
    Apr 27, 2017 | Kenmore HE2 Plus Front Load Washer
    How much oil do i put in the rear shok for a yz250
    You can change it. Im looking for the correct amount to do it myself. I already pulled mine apart and bought a rebuild kit for it. Comes with a new nitrogen bladder, o rings for the seal, and a few other necessary items. Just remember to measure where the jam nuts holding your spring is so you can put it back in the correct location. As for the nitrogen i heard 150 psi. I'm fortunate to work at an offroad racing shop so i'm just gonna fill mine with nitrogen there, but i dont think you should get charged too much at a regular bike shop. Rockymountainatv.com has the rebuild kit. You will need the seals atleast. If i find anything else out i'll let you know. Hope this helps.
    Mar 15, 2009 | 2003 Yamaha YZ 250
    Information on how to change rear shock absorbers
    with great difficulty,three bolts hold the plate that takes the top bush/mounting .jack vehicle up and support with axle stand .Another jack under rear axle ,jack this one up till cars starts to lift then fit the spring clamps and compress the spring.Next undo the 3/4 13mm headed bolts that hold the plate to the chassis ,if you can release them???---??? ,then next using a small bottle jack take the strain on the bottom of the shock absorber and then remove the bolt ,lower the jack and the top one will lower as well ,undo the two nuts on the top mounting and pull the old shock absorber out .Or what i do if back is dancing and thats to do as above to support vehicle ,support lower of shock absorber ,remove the bolt and then jack it up ,then drill a small hole about an inch from the top of the tube and then thread it ,refill the shock absorber with a heavier oil like dextron .fit a bolt into the hole with a rubber washer and its as good as new
    Aug 12, 2008 | Jaguar XJ6 Cars & Trucks
    Kenmore Elite 45986 Front Load Washer Logo
    2,953 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Carew
