Question about Zebra TLP 2844-Z Thermal Label Printer
Tlp2844 label move in then come-out. is there any setting to let label always comeout
    Scholar:
  • 62 Answers
When using Zebra Designer select File/printer settings/advanced setup and tick the Top of Form Backup box, click ok and save file to retain the changed settings.
Posted on Jul 20, 2009
TLP 2844-Z Thermal Label Printer: can the tlp2844 be programmed with zpl?...
If you have an Eltron version, it can't be reprogrammed to support ZPL. It will require replacement of the Main Logic PCB = expensive
May 03, 2010 | Office Equipment & Supplies
Every time I print a label, the label comes out.
Have a look at the way the driver is setup, by sound of it you might have it set for thermal transfer, it needs to be set to direct thermal. Thermal Transfer is for the TLP2844. the next time you print will send the changes to the printer
Oct 12, 2009 | Zebra LP 2844 Thermal Printer
Automaticly deletes documents before
Check the settings of the printer. In the mean time, copy all the printable files to a new folder for safety reasons. Copy them and NOT move them. meaning you have a backup till you sort the problem out.
Aug 07, 2009 | Zebra Eltron TLP 2844 Thermal Label...
My zebra tlp2844 wont print, the red light on, i think we set the reverse sensor on , after it got this trouble. What should i do?
Well are's was acting like what you discrive, I found that the ribbon,core tube has slots in the ends, this slots were, wear-out the ribbond wasn't moving thas why we were getting the red light, (error light) We install new rolls of ribbonds.
Aug 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Hi there! I work with Zebra TLP2844 through
If you are using Bartender, Make sure to use the Seagull Scientific Zebra Driver. The zebra driver works (but not properly) with bartender. Download the driver from Seagull Scientific site. You can also email bartender tech support, their contact details are available from the help screen on the main bartender design screen. I have always found them to be extremely knowledgeable and helpful.
Jul 01, 2009 | Zebra LP 2844 Thermal Printer
TLP2848Z blinking red, will not print
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
Calibration:
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
Calibration:
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Dec 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP2844 print output very light
The problem was the power adapter appeared to be not original, instead of the required 20V this one produces 15V, found the original power adapter and the printout looks fine, darkness looks ok now.
Regards,
Edwin van Hek
Oct 14, 2008 | Zebra tlp2844ps Thermal Label Printer
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Zebra TLP2844 Prints Centered and Half the Width
create a word template document with the page size the same size as the label. Set the margins to 0 and fill the label up with text. This should make the printer print right the way over the bale.
Nov 21, 2007 | Zebra Eltron TLP 2844 Thermal Label...
Zebra TLP 2844-Z Thermal Label Printer Logo
231 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
