VCR ejecting my cassettes
Hi,I have a 'TruTech' VCR Recorder/DVD Recorder Combo and one day, I put a blank cassette into my VCR section and started recording. When it came to the 20 seconds after the recording began, the entire Combo just turned off. When I pushed the power button, it turned on and ejected the cassette. I still didn't figure out what's wrong. I didn't do anything to cause it, and it is just so random. Also when I'm rewinding, fast forwarding, playing the cassette, on about the 20 seconds after I begin the operation, the VCR terns itself off for no reason and when I turn it back on it ejects my cassette. I tried using the ''Cleaning' cassette but it gave no effect. Therefore, my DVD recorder is working perfectly. And it's not a problem with the OTR.
I will much appreciate if any one would know how to fix that.
Thank you.
  • 458 Answers
Try removing the top cover & have a look to see what happens when you put the tape in & press play/rewind etc. Is the take up spool (right hand spool) turning properly or is there slack tape not being taken into the cassette? Are the heads spinning ? I think your problem is more likely to do with the tape not travelling smoothly around the tape path. Possibly the clutch gears need cleaned or the soft brakes may not be dis-engaging properly.
Posted on Jul 20, 2009
After tape starts to play, why is it ejected and player shuts down?
The tape may be defective in some way such as wrinkled or slack in the cassette. If other tapes are handled the same way, the fault probably is in the player mechanism.
Jan 05, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
Video Cassette is being automatically ejected when I insert it for viewing
You need to take the cover off and look inside to see if there is something inside that should not be. Perhaps you can look with a flashlight through the entrance hole. You could pick up the machine and shake it and see if anything is rattling around. These things have many plastic and nylon parts which can break over time and the machine will sense a problem and eject. If you cannot find a problem by the suggestions above then it will need to go for repair-unfortunately it would probably cost more than it is worth to have it repaired.
May 16, 2014 | Goldstar GBV241 DVD Player/VCR
Govideo DVD/VCR combo, vcr side not playing properly and won`t release the tapes.
MAKE THIS TEST AND FIX IT. God bless you
1.
    • 1
Make sure the device is plugged into the household power supply and is switched on if no indicator lights are illuminated on the control panel. Watch for any power-saving technology that can shut the recorder down when it's not being used. Try the "Power" button again.
    • 2
Verify that the media you are using is compatible with the device. Most combos record to DVD-RAM/-R/-RW/+R/+RW Discs on the disc side. VHS cassettes can have erasure tabs, so check that the tab is still there if you can't record to the cassette. Watch out for copy-protection technology on either the tape or disc. Often it's indicated on the packaging. Copy protection is designed to stop illegal reproductions, so may block many recordings of copyrighted material.
    • 3
Connect a television to the "Video Out," "S-Video Out" or "Component Video Out" jacks on the DVD-VCR combo if you can't see video from the combo playing on the television.
    • 4
Forcibly eject a disc if it is stuck in the combo. Often, manufacturers will create a sequence of buttons to use that accomplishes this. On a Panasonic, you force the combo into "Standby" by pressing "Power" for 10 seconds. Then press and hold "Stop" and the "Channel Up" button together for five seconds, and the disc should eject.
Oct 30, 2013 | Televison & Video
Trying to do a timer recording to a Toshiba SD-V296KU DVD Video Player/Video Cassette Recorder. all seems to go with the recorder device but when I do the playback it is a blank screen. Is that because the...
I have a Toshiba DVD Video Player/video Cassette recorder - the problem is that when I set the VCR to record for an hour it will record for less than that hour and eject the tape. Help!
Mar 01, 2011 | Sansui HDLCD-4212 LCD TV
Tape loaded normally but now won't eject. The unit just powers off after a few seconds.
Unplug the power from the combo unit and give it 30 seconds, now plug back in, sometimes this will eject the tape, if not! take the top off the machine and check to see if the tape is spewed in the mechanical section and around the video head, if yes! get a pair of scissors and cut the tape carefully to avoid damaging the video head and remove all tape deb-ri, now power up and eject the main cassette. But! if you find the cassette has loaded in place and the tape is still in the vhs cassette, this would indicate a loading problem with the main carriage, broken belt, bad idler assembly and possibly sensor issues.
Feb 06, 2011 | Sony SLV-D350P DVD Player/VCR
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Sep 06, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
238 people viewed this question
Top Televison & Video Experts
