Question about Garden
Do I turn the faucet on fully?
I have bought a Water timer Vigoro 196036 and my question is:
I am using a drip irrigation system and that uses very little water and the instructions for the water hose are to only open the faucet very little.
Is that the same when I am using the Water timer?
  • 22 Answers
Yes, when using an inline water timer, it does not control the pressure of the water, only the "on/off" of the pressure. So make sure to keep the faucet at the pressure you want the drip system set at as if you weren't even using a timer.
Posted on Jul 19, 2009
I'd suggest using a trottling valve DOWN STREAM of the on off timer. There are cheap plastic gate valves and even a ball value can be used control flow. Some valve timers do require a minimum pressure UP STEAM to stay open, so throttling UP STREAM of the timer may not work.
Posted on May 03, 2015
Do I place this at the faucet or after the pressure regulator on drip system?
Generally you put these timers at the hose bib (faucet). In my home, they'd be used for sprinklers or drip irrigation systems that have a limited controls on them. If I put them past the flow restrictor on the soaker hose, the unit would be on the ground and in the water.
I hope this helps.
May 10, 2014 | ACE Water Timer, Electronic - No. 7198476
Can I use a drip irrigation system for my garden's flower pots?
Yes. You can buy drip kits that consist of a timer, hose and emitter. The hoses for flower pots are the 4 mm diameter ones.
Sep 10, 2013 | Garden
What is a Drip Irrigation System?
According to Wikipedia "Drip irrigation, also known as trickle irrigation or micro irrigation or localized irrigation, is an irrigation method that saves water and fertilizer by allowing water to drip slowly to the roots of plants, either onto the soil surface or directly onto the root zone, through a network of valves, pipes, tubing, and emitters. It is done through narrow tubes that deliver water directly to the base of the plant."
Water won't stop after removing a electronic water timerfrom hose
turn off water ar meter
remove valve or guts fron tap on wall and replace ruber washer
option 2 go to wallmart and buy a mini ball valve screw it on wall facet and turn it off voila it now turns off 3.99 and your grass is no longer a swamp
Jul 25, 2009 | Garden
Water is trickling out
No. Check to make sure the battery is good. If so, and you just purchased the timer, take it back.
Jun 24, 2009 | Garden
Garden Logo
505 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
