Question about Kenmore HE2 Plus Front Load Washer
Washer is not spinning quickly on teh spin cycle. It turns but very slowly
  • jmgnetmail Jul 19, 2009
    Its the HE2
    I think it is 110 44832 200
    It also says type 199 AKP 705/wt
  • 1,000 Answers
Can you provide me with the model number please.
Thanks,
Regards,
Posted on Jul 19, 2009
  • Bruce Bracey
    Bruce Bracey Jul 19, 2009
    It should be a longer set of letters and numbers, some possible places to look are:
    Look at following areas for the model number
    • Rear Center Of Lid Well
    • Left Upper Back On Base Cabinet
    • Back Top Control Panel
    • Right Rear Corner Of Washer Top Lid
    • Open Lower Left Front Base
  • Bruce Bracey
    Bruce Bracey Jul 20, 2009
    The 110 44832 200 number is correct.
    First thing to do is to remove the rear access panel and make sure the drive belt is tight(item #3 below). Tighten by adjusting the motor.
    If the belt is slipping you will not get the tub to spin fast enough. Also check the belt to make sure it is not cracked, worn or frayed. If so, the belt will need to be replaced.
    Check that first and let me know. If it turns out the belt is tight we will have to move on to the motor.
    Let me know.
    Regards,
The door is closed good. However, the washer will not spin.
if it spins slowly but atleast spins? You may have a slipping clutch, bad brake assembly or if belt driven a loose or worn belt. maybe even a worn down motor coupler
Sep 15, 2014 | LG WM1814CW Front Load Washer
My washer sounds like it is pumping water out during teh spin cycle, but the tub is not spinning. I have opened the front and the belt looks good. Any thoughts?
usually the washer pump will remove excess water for a few minutse this happen too most washers i have seenm after a few minutes it should kick into another cycle to spin it.
Nov 28, 2010 | Frigidaire ATF6000ES Front Load Washer
My fridgidaire front loading washer just recently stopped working on the spin cycle, it doesn't even work on the spin/drain cycle.
More than likely a bad door switch, as it won't go into the spin if the board doesn't like the reading it gets from teh switch. They fail quite often. Part number is 131763202
Apr 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
Washer spins slowly
your clutch pads are worn out they sell a kit to repair that
Feb 04, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag neptune in spin cycle goes slowly fav6800aww
Hello smithe623
I’m an owner of the machine.
I assume the machine is not displaying and error code to the LED Display?
I would download the Service Manual and go to page 14 and perform the Quick Spin Test in Service Mode.
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
The Quick Spin Test will spin the wash basket up thru all RPM ranges starting at 90 RPM .15 =150 RPM, .35 = 350 RPM all the way up to .85 for 850 RPM. Report back on the results of the Quick Spin Test and we will go from there.
You can get out of Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or press the off button on the console.
Take care…..Rich
Nov 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
