Home | Polaroid | FLM-2632 Television | No Picture in my 1 Yea...
Polaroid FLM-2632 Television
Problem for Polaroid FLM-2632 Television
No Picture in my 1 Year Old Polaroid FLM-2632 LCD TV
By UCFRon on Nov 19, 2007
All of a sudden, my picture what to black in a one year (and 3 weeks) old TV. The sound works well and I can change stations, but no picture. No lines, no fuzz, just black.
Comments:
Dec 22, 2007
- Ok, where is the back light located? I have the back open, what do I look for?
Same Problem
May 25, 2009
-   I just want to know if it is possible the my polaroid tv can be fixed an if it is worth while doing so. The picture went black, but there is sound.-   Guest
Mar 30, 2009
-   I have exactly the same problem and I can't locate the capacitor either and I do not know what size I need to purchase if I could find it.-   j_crider
Mar 12, 2009
-   I have the same problem, I can watch TV or play my ps3 and then all of a sudden the picture starts to flicker, and then it goes out. After this happens I can still hear the sound, sometimes if I wait a minute the picture will come back on, and sometimes I will have to turn the TV off for a while. The local TV repair shop will not even fix Polaroid TV's since they went out of buisness, they cannot get the parts. I have the thing apart, but I am not sure what I am looking at. I am pretty mechanically inclined and am adept with my hands, but this is the first TV that I have actually taken apart. Does anyone know what the power supply or these green capacitors are supposed to look like? -   cocheeze15
Dec 03, 2008
-   model 3732 purchased 02/07,no pic or sound-   Guest
Nov 10, 2008
-   My tv is a little over a year old. A few months ago, the screen started randomly going black. We found that turning it off for awhile and then back on again works for a bit. This is extremely frustrating. Reading the responses on here, I may be taking it to a repairman soon! Thanks everyone and good luck! -   dana_shae23
Best Solution
posted on Oct 08, 2008
Very Helpful)
tomycombs
Rank: Apprentice
Rating: 100%, 5 votes
had the same problem. if you take out the power supply in the back of your tv ( easy to get to just a few screws in back to get to the box then a few more to get into it and some quick disconnects) you can take it to a local tv repair shop and they can remove the two green capacitors in the upper left of the circuite panel and place in 16v ones that can actually handle the power needed. do not try to do it yourself although the new capacitors only cost 2 dollars one wrong move and you burn the wires on the board. the repair man only charged me 54 dollars well worth it considering polaroid wanted to charge me 500 to fix a 2 dollar part that should have been recalled. they are in the busines to make money but if any of us did what they did wede be considerd con artist. final note since ive replaced the capacitors my tvs worked better than when i bought it
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on Jul 22, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Nice Try everyone, We are an Authorized Service Center For Polaroid, and where the problem is in the Power Supply! This supply generates standby 5VDC when the PW_on Pin goes High, It will produce the 12VDC and the 24VDC for the Backlight (inverter) , But the Problem is in the Electrolytic Capacitors in the Power Supply!
Solution #3
posted on Nov 07, 2008
Helpful)
occfan43026
Rank: Apprentice
Rating: 84%, 4 votes
i have the 32" lcd tv and i have power to the tv when its plugged in and when i go and turn on the tv nothing happens i get no picture can anyone help me a buddy of mine says its the back light inverter but idk
Was this helpful?
Yes
No
Solution #4
posted on Sep 06, 2008
Helpful)
wpeterson12
Rank: Apprentice
Rating: 83%, 3 votes
I have the same issue and checking power supply have solid 5VDC and 24 VDC. Backlight works since the Polaroid logo displays then goes black
Was this helpful?
Yes
No
Solution #5
posted on Dec 06, 2007
Somewhat Helpful)
legna
Rank: Wiz
Rating: 78%, 107 votes
The back light is gone you might need to replace it. Open it and check the back light is easy to access.
Was this helpful?
Yes
No
Solution #6
posted on Nov 08, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
After noting all the possible issues, I suggest anyone with a SMALL investment like I have, chuck the TV and post the experience under lessons learned (listening Polaroid CO.) People with larger investments, I feel for. Hope you can work it out. EVERYONE ELSE, STAY AWAY FROM POLAROID.
Solution #7
posted on Dec 13, 2007
Somewhat Helpful)
Chris Mc
Rank: Apprentice
Rating: 58%, 6 votes
Sue Polariod
Was this helpful?
Yes
No
Popular Solutions for Polaroid FLM-2632 Television
Questions and Unsolved Problems for Polaroid FLM-2632 Television
Do you recommend Polaroid FLM-2632 Television?
Answer
Answer
There is a very loud static electricity sound through the volume on my television. It is not coming... (More)
Answer
i have a coby TF-TV1901 (19"lcd flatscreen).hooked cable up and had picture for 2 seconds then... (More)
Answer
I can't get the tv to display full screen on reg. or hd channels. I have two bands on either side of... (More)
Answer
dog eat remote, replacement remote does not work tv, need code , polaroid flm-2632 lcd tv
Answer
When we turned on the tv it says no signal vga input? It is a polaroid Flat Screen hdtv.
13 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Sep 08, 2008
Our tv is 9 months old. First it would flash as though stuck on slide show which we never used. Then it went black( still could hear sound ) and I noticed a smell like wires or plastic burning.
Comment by wxmike, posted on Aug 24, 2008
Exact same problem with mine, after about 14 months of use. Did anybody find a solution? Want to know before I drop money on a repair or replacement.
Comment by JERSEYJOEYD, posted on Jul 21, 2008
My problem is IDENTICAL to UFCRon's. I have no idea what to do. The TV goes in the garbage in a few days.
Comment by Guest, posted on Jun 21, 2008
I HAVE THE SAME PROBLEM FEW SECONDS AFTER I TURN ON MAY TV THE SECREEN GOES BLACK.
Comment by Guest, posted on Mar 26, 2008
i turn my tv on...i will work for a few seconds...and then the screen goes black...my tv is less than a year old...sound works great still...help
Comment by Guest, posted on Feb 02, 2008
No picture
Comment by Guest, posted on Jan 02, 2008
I AM HAVING THE SAME ANIMATION ON ALL SHOWS PROBLEM. I WOULD TRY TO RESET THE FACTORY SETTINGS, BUT HALF THE TIME MY MENU WON'T APPEAR WHEN PUSHING THE BUTTON AND WHEN IT DOES I CAN'T READ IT.
Comment by Guest, posted on Dec 13, 2007
My picture looked like it was animated even though it was a real live show. I fixed it twice be resetting factory default settings. The third time I couldn't navigate through the menu to fix it. It is just now 15 months old, 3 months over the1 year warranty. Polaroid is offering no help. I took it to a repair shop and they said it needs a control card ($350-400). Does anyone know where I can get the part and hopefullly for less money?
Chris Mc
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Polaroid FLM-2632 Television:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
