Question about Radio Communications
Hello, I want to change the frequency to the
Hello, I want to change the frequency to the range from 28,0000MHz to 29,7000MHz.
Please inform the modifications needed.
Regards, Kjeld
  • daniel doyle May 11, 2010
    What brand and model is the radio ?
  • 64 Answers
What kind of radio?
Posted on Sep 13, 2010
I have a Motorola Axu4100 , I want to change the frequence that I currently have on this radio to a Motorola CP-200...just wondeing if these two radio can work together....
Hi
Motorola CP-200 have frequency range
VHF: 136–162, 146–174MHz;
UHF: 403–440, 438–470, 465–495MHz depending on the model
Motorola AXU4100 have frequency range 435 - 480 Mhz
The first model has a wider frequency range so it is best to include transmitter Motorola Axu4100 to transfer and try to receive signal to Motorola CP-200
Sep 03, 2010 | Motorola AXU4100 (10 Channels) 2-Way Radio
Error message when trying to enter frequency codes into the Radio Shack Pro-433... How do I enter the frequency codes I have into this scanner?
The error message almost always means that you have either entered a frequency that's out of your scanner's tuning range, or that you've neglected to enter a decimal point in the frequency. Check your operating manual to verify that the frequencies you're programming are within the unit's tuning range. If you don't already have the manual, you can download/print it here:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000433_PM_EN.pdf
You can also find a wealth of useful scanning information, including a database of active frequencies in your area, by visiting:
www.RadioReference.com
Bill B
Jul 04, 2010 | Radio Shack Pro-96 Scanner
Need a free printable user manual for Bearcat scnner BC142XL
Its so easy to use you really don't need a manual for the Uniden BC142XL scanner.
Turn it on. Push the "MANUAL" button to stop it from scanning.
Push number 1, then push "MANUAL" again. This should leave you on channel one.
Using the keypad enter the frequency you want to monitor, then push "E." Press "REVIEW" at anytime to see what frequency is programmed there. If the review button flashes 000.0000 on the LED readout display, you might be entering an invalid frequency. Refer to the list of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push "E." Push "MANUAL" to step to channel three. Repeat this process until all the (10) channels are full, or you've run out of frequencies to enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two seconds after the conversation has stopped.
Frequency Range Bands:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band
If this helps, please take a moment to give us a rating -- and a rating of "very helpful" would be greatly appreciated.
Sep 06, 2009 | Uniden BC-95 XLT Scanner
Range Rover Sport Supercharged radio frequency problem
you need 2 remove your radio and open you shloud change the ic for frequency to work it is very easy to change it if youneed ana help contact me
Aug 20, 2009 | 2006 Land Rover Range Rover Sport
What do hpf and lpf switchs do
Hello rwalinske, The abbreviations "hpf" and "lpf" stand for High Pass Filter and Low Pass Filter. They do exactly what their names imply. They allow frequencies above or below a specific setting, while blocking or attentunating frequencies below or above the setting. There's also a "band pass filter" which allows frequencies within a specific range below the high setting and above the low setting. Finally there's a "subsonic" filter which blocks inaudible frequencies below the threshold of hearing. The hpf is generally used in speaker component systems to send the high frequencies to the tweeters. The lpf is normally used with subwoofer systems and is set to send frequencies below the setting to the subwoofer. While most amps will amplify a wide range of frequencies, they are more efficient when the range is limited depending on their intended use. For example, a typical 2-channel amp might have a frequency response of 20-20KHz. When used to drive a set of normal speakers, you would not use either the lpf or the hpf, but simply let it send all frequencies to the speakers. But when used to drive a subwoofer, and operated in "bridged" mode, the amp can put all of it's amplifying power into frequencies than can be used by a subwoofer if the lpf switch is turned on. Hope this helps.
Jun 05, 2009 | Sony Car Audio & Video
How to change frequency range in LCD moniter
Good morning! please try to review/check the operations manual of your LCD monitor, wherein proper set-up settings of Frequency range can be noted. best regards.
May 04, 2009 | X2Gen MG15VT 15" LCD Monitor
Vpl-es4 sony projector-frequency out of range
Pl. send me solution. I am stuck with problem
vpl-es4 sony projector-frequency out of range.
Sep 26, 2008 | Sony VPL-ES4 Projector
Talkabout T5720 Frequencies
Hello Ruaal,
The frequencies in the TalkAbout T5720 are not adjustable. The radio operates on the designated Family Radio Service channels located at 462 and 467 MHz. There is no way to change these channels to be at 463 and 464 MHz.
Best regards,
Ken
Go Ahead. Use Us.
May 14, 2008 | Motorola Talkabout T5720 (7 Channels)...
Signal out of range?
Using your CRT, open the properties of the video adapter. Look for the refresh rate and set it to 60Hz. This should fix your problem.
Hope this helps, and please rate my advice, good OR bad.
Thanks, and good luck!
Feb 02, 2008 | Balance CM2017 17" Monitor
Radio Communications Logo
67 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
