SOURCE: JVC KD-G400 Radio reciever
Try pressing select or Fm/Am button + button 5 for 3sec the disply should say eorope. Good luck
SOURCE: DOESN'T WORK AFTER INSTALLING A NEW CAR BATTERY
did you check the fuse on the back of the radio. it should be a small maxi fuse that might be rated any where from 5 to 20 amps. most of the time it might be helpful to unplug the radio harness and re plug it after 1 minute.
SOURCE: setting clock on jvc radio
Hey here is an instruction page for your clock.
http://resources.jvc.com/Resources/00/01/13/LVT1775-001B.pdf
SOURCE: JVC KD-G310 stopped working after battery change
have you pulled the deck and checked the built in fuse beside where wiring harness plugs in
