I NEED THE DISK TO WIPE ALL THE CRAP OUT OF MY COMPUTER AND RESTART WITH ITS ORIGINAL SETTINGS.
When you restore your system back to the new factory settings, it will wipe your hard drive clean and do a fresh install of the operating system with the original factory setting.
To start this process, unplug all extra devices from your computer
(printers, external hard drives, etc.) as these can interfere with the system restore.
Starting with Windows XP, most systems with issued a system recovery disk in case of any problems with the factory installation.
Check the documentation and disks that came with your computer to determine if you have one of these system disks.
If you do have a copy of this disk, place it in your CD/DVD drive and restart your computer.
If you do NOT have a copy of this disc, skip to step 3 for further instructions.
Once you restart your computer, a screen will appear with the words.
Press Any Key to Boot From CD. Once you press a key, a screen will come up containing instructions to format your hard drive and restore the original factory settings.
Follow the on-screen prompts to finish the installation.
Once the restore is complete, remove your Recovery CD from the disk drive so that your computer does not try to boot from the CD again.
Restart your computer to complete the restore.
3. If you do not have a System Restore disk, then your computer should have a recovery partition on your hard drive, separate from the main partition of the disk.
Unplug all external devices and restart your computer.
When the loading screen comes on with the Windows logo, press Alt+F10 together five times.
This will bring up the system restore menu.
Follow the on-screen prompts to restore your computer back to the factory settings
hope this helps
You can start the Recovery from outside windows by holding down the ALT key and tapping F10 repeatedly
on startup. When the recovery loads you will be prompted for a password.
This should have been set by the customer if they have been into the Acer Recovery Management software previously.
If they have forgotten the password or you wish to clear the password you need to boot off the recovery disk that should have been created.
More Information
From the Acer toolbar at the top of the desktop click on the disk icon
Setup a password if requested.
After clicking on setup you need to click Create Password to continue.
Create a password and add a password hint (strongly recommended).
You now have the option of restoring from a previous Windows Vista backup or you can start the Acer recovery process.
The recovery is started by clicking Restore at the bottom of the window.
Further types of recovery are now presented.
Choose Restore system to factory default if you wish to run the hard drive based recovery and return your Acer computer back to it's original factory default state.
Note: The factory default recovery will wipe ALL data from the computer so ensure important data has been saved to disk before proceeding.
Enter the password that was previously set.
Confirm you wish to run the recovery process.
After confirming you wish to run the recovery process the computer will restart and restore all the original files
Complete the Out of Box Experience when prompted
After a couple of restarts the computer will run through restoring the preinstalled software that came with your computer and then be ready to use
hope this helps
at startup the aio software npi shows and I do not have the disc. Trying to cancel tjis completely off tje startup menu
