Question about Kenmore Kitchen Ranges
We took apart our kenmore gas stove because a rat had been living in it. We cleaned it up and now can't put it back together! We are looking for an assembly manual. Please help.
How do I open the top of my Kenmore stove to clean under it? I am trying to clean it because some of the burners don't want to light when I turn the knobs.
Posted on Dec 20, 2009
I guess while loading and unloading I notice gas on and off value was loose . I took it apart and I found few pieces and spring laying at the bottom tray . I couldn't figure out how it goes together .
it was faulty before you inspected it
call a qualified gas stove repairer
i would ask about a replacement
putting a faulty gas part back together
may give you the same leaky gas on off switch
Sep 26, 2016 | Office Equipment & Supplies
How do you take off toe panel from he3 electric kenmore dryer to clean plugged lint
Hello;
My name is Peter. I am a retired field service appliance technician.
There are two spring clips, one on each side of the bottom toe plate panel.
Dec 02, 2014 | Kenmore Dryers
Oven door
Nectar time take a photo first, they generally only go back one way.
removing the door may make it easier open the door see the hinges on the bottom lift up the little cam on each hinge then just lift the door up & it should come out.
Apr 17, 2014 | Kenmore Sears Electric Range Stove Oven...
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Kenmore gas stove Gas leak
I had this problem with my stove and had the regulator changed coming off the PROPANE tank.
Apr 04, 2017 | Kenmore Kitchen Ranges
Trying to figure out how to put back together an old 1950's Merritt and o'Keffe stove that someone took apart to clean and couldn't put back together again. It worked before they tore it apart but is in...
Good luck. I would myself try to find a general stove schematic and work out how different it is. There may be a few different rated thermostats and elements, but the bulk of the wiring pattern will be similar.
It may have to come a bit of trial and error as well.
(also, they disassembled the wiring to clean it? that's thorough!!)
Hope this helps, let me know.
May 09, 2009 | Kitchen Ranges
Rat Nest in oven insulation
No the insulation must be replaced . the insulation makes the oven cycle on and off less frequently and also keeps the exposed metal surfaces cooler.
Dec 19, 2008 | Tappan TGF320 Gas Kitchen Range
Dishwasher pump not working
if you go here http://www.searspartsdirect.com/partsdirect/index.action and enter your model number without any spaces you can get a parts list on that page you will see show diagram it will give you a blueprint of the pump moter assembly
Jan 30, 2008 | Dishwashers
Putting dryer back together
if whirlpool are kenmore the pulley slides in tobottom of the dryer in front motor there a slot it goes in
Dec 24, 2007 | Kenmore 64952 Electric Dryer
Kitchen Ranges Logo
225 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
