When my water runs it wont shut off and my wash cycle will not engage
    Sergeant:
  • 272 Answers
You need to check a few things..#1..if water continues to run in after you turn off machine the water valve is most likely bad...if the water stops when you turn it off. its maybe the pressure switch...you may need a technician...Bruce
Posted on Jul 19, 2009
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
The cycle will run and fill with water and then shut off. the sprayer wont pop up and spray water
sounds like your dishwasher is on it's last wash cycle the motor that pushes up the sprayer is out time to get another one
Mar 23, 2011 | Kenmore Dishwashers
WATER IN WASHER WONT SHUT OFF
Hi and welcone to FixYa. I am Kelly. When water wont shut off no matter what you do the problem is inside of the water valve assy. Usually there is a small bit of debris in the diaphram center hole that is holding the water passage open.
Here is what you can try to do to clear if BEFORE replacing the eater Valve.
1. Get a bucket
2. Turn off both water supply hoses momentarily
3. Set the water temp to warm
4. Remove ONE hose from the wall connection and place the hose in a the bucket.
5. Turn on the remaning connected hose/
6. Start machine fill cycle and tap the hose connection at the water valve on the back of the machine with either a screw driver or hammer handle.
Timer OFF
REVERSE HOSE CONNECTIONS ON THE WALL CONNECTION.
7. Place the other hose in the bucket
8. Start Fill cycle.
9. Again tap the hose connection at the water valve
10. Stop timer.
11. Reconnect both hoses and test for water flow with timer off.
12. Start fill cycle
13. Rapidly select hot and cold wash water.
14. STOP fill cycle.
15. Remove each hose individually from the water valve one at a time.
16. Use a knive blade and remove the inlet screen from the water valve. Wash screen under slowly running water rubbing it clean with your fingers. Re install screen. Reconnect water hose.
17. Repeat step 16 for opposite hose and screen.
18. Turn on water supply.
19. Test for proper filling and water stopping by starting and stopping fill cycle.
If it works you got lucky. If you still have the problem you will need to change the water valve. Either one of these water valves will work on your machine:
http://www.repairclinic.com/Appliance-Parts?s=t-PAV2300-%3d%3dc292d509361
Thanks for using FixYa.
Kelly
That is about it
Jun 05, 2010 | Maytag PAV2300 Top Load Washer
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
The water wont shut off
Hi, It sounds like the mixer inlet valve has gone bad.
Did you try and shut the power off to the waser first with no results?
Please let me know so I can assist you.
Thanks
Vic
May 27, 2009 | Kenmore 24032\24036 Top Load Washer
Doesn't fill with water - goes straight to agitation.
open the console and find the pressure switch. it has a clear hose attached to it. pull the hose off the switch and turn on the washer. if water starts to enter shut it off and blow through it back to the tub. some piece of junk may have plugged it causing the switch to "think" the tub is full of water. put the hos back on and run a short spin cycle to reset it and try again making sure to run a small load to see if it shuts off properly. if no water enters when hose is pulled off most likely bad pressure switch. keep the lid closed while doing these tests. some units wont work w/lid open.
May 25, 2009 | Whirlpool Washing Machines
Check water valve. Solenoid may be stuck. This is where your hoses attach to, all one unit.
May 25, 2009 | Kenmore 24032\24036 Top Load Washer
Washer ultimate 11
probably bad fill valve ..if water continues to run in when machine is off valve may not be shutting off completely due to trash if screen in cold inlet has been removed to clean and not reinstalled trash can enter valve and prevent complete shut off ..remove 2 screwson back of console pull console forward and roll back pop 2 clips 1 each corner remove lid switch plug cabinet will lean forward and off to acess valve
Sep 02, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Water will not shut off
Check the pressure tube on the water level gauge.It may be clogged.
Jul 30, 2008 | Hotpoint VBSR3100D Top Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
