Question about Panasonic Th-42px25u/p 42-inch High-definition Plasma Tv
I have Panasonic High definition plasma TV. Model No. TH-42PX25, Manufacture 2004. Will not turn on. What could be causing the shut down problem?
I have not yet taken the back cover off. I notice the when turning the set on, the scream attempts to turn on then shuts down. I also notice that when, turning the set on, am getting 12 blinks on the lower left side LED.
SOURCE:
  • 330 Answers
SOURCE: my panasonic tv got problem
when it is warm, shut off, then after take a rest it will automatic on again, probably you need change the on anf off switch.
How long have you had the TV?
Posted on Jul 10, 2008
SOURCE: I have a panasonic plasma tv. Model #
I don't know but I'm having a similar problem. I have a plasma
TH-50PZ77U. It will run for a while and then shuts off. Also, the volume goes up and up and then it shuts off at times. Like I have a ghost here. I had both of my sat. recievers replaced. It seems to get worse over time with shut down. I called panasonic and they had no info and denied this was an issue but I beg to differ from my research here online. It's only a few years and we paid lots of $$$. They gave me a # for service 1 hour away!
Posted on Jul 11, 2010
lovejoy91
  • 691 Answers
SOURCE: My Panasonic Viera TH-42PX80U plasma TV shut down
Bad power supply check shopjimmy.com
Posted on Jan 13, 2011
  • 184 Answers
SOURCE: Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Posted on Aug 01, 2011
  • 24 Answers
SOURCE: Panasonic th-42pz80u...dead set...red LED blinks
I'm no expert but I have the same tv I'm trying to fix,different problem from yours.I think you can take a resistance reading from that pin to ground and if there is a short,you can start unplugging different boards and when you have the right one the short will go away,if not its the power supply.Put in a search on google with something like board layout for TH-42PZ80U and click on the link 11th generation and you can tell if I told you right or not
Posted on Oct 13, 2011
I have a Panasonic plasma TV model# TH-42PX75U --- here is a link to Panasonic web site for this model...
Unfortunately your going to have to have it serviced by an Authorized Panasonic Dealer. Independent shops will not be authorized to order parts without the consent of Panasonic. They are rough to deal with.
Dec 20, 2010 | Televison & Video
Jun 20, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
Th-42px25 red picture, no blue or green
If using component cables check connections at TV or from source. If all rae ok the try source on another tv before getting video input circuit board replaced on tv
Dec 14, 2009 | Panasonic TH-42PX25U/P 42 in. Plasma HDTV
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Apr 24, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Our 42" Panasonic Plasma tv
As posted for a similar problem:
This is an issue with IC 803 on the Z board. This is a 3.3 V regulator that supplies this voltage to the slot card cage. Most input boards use this voltage EXCEPT the component board which is why it keeps playing along whike the DVI, HDMI, or composite signals will cut out after warm-up.
This is a surface mount multi-pin IC and is a bit tricky to replace.
The entire board is PN# TNPA3198xx with suffix determined by what model 7 series plasma you have.
This was a problem from around Nov. 2004 to Mar. 2005
T Wiz
Feb 26, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Panasonic Viera Plasma TH-42PV7HS- Shutting down
CHANGE P.A BOARD. THIS BOARD IS FOR TUNNER VOLTAGE..IF THIS BOARD IS BAD, THE LED FLASH 10 TIMES IN RED AND THE TV NO TURN ON.
Oct 30, 2007 | Sony KLV-S23A10 23 in. LCD HDTV
Panasonic Th-42px25u/p 42-inch High-definition Plasma Tv Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
