Lg WM0532HW washing machine control panel say OE and the door is locked
    Novelist:
  • 108 Answers
"OE" means that your drain pump is blocked, or possibly broken, and that water isn't emptying so that the machine can spin. (I think Outlet Error is what it stands for). If you have a wet dry vac, you can use it to vacuum out the water from the drain hose behind the small door on the lower left side of the machine. If not, you can try using a large pan to catch the water, but to be honest, it will take forever and won't really get all the water out. Try to borrow a wet vac if you don't have one.
Next you will have to open the pump trap (the cap thing next to the small drain hose). With the wet vac on and in position, loosen the trap and pull it out slowly (there will still probably be a bit of water in there). Hopefully you will find a bunch of junk in the trap like lint, coins, a sock, whatever... however you may find there isn't anything in the trap. which means we have to go in deeper.
You may just want to get a pro in to do this, but it isn't really all that difficult for the adventurous type. You have to remove the top of the machine (three screws at the back release it so that the top panel can slide back a couple inches and lift off,) pull out the dispenser drawer completely, the control panel (you don't have to disconnect the wires, just pull it away from the frame of the machine so that it reveals the screws that hold on the front panel) Then you have to remove the front panel, which includes pulling off the spring clamp that holds the gasket to the front panel, and the wire which activates the door lock. There is also a screw behind the plastic piece where the drain hose is.
Once you can get to the pump, unscrew the motor on the left side of the pump and remove whatever is blocking the pump impeller from turning... even a tiny nail can do it.
Posted on Jul 19, 2009
  • 6,784 Answers
This is a drain issue. check the following.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Always drain the machine and check the trap first. Access to drain hose and trap is located on lower left front of the machine, If not using a wet vac use a shallow pan and have a large capacity bowl nearby to empty the pan as it becomes full. Use a coin or screwdriver to twist the small black plug and the hose will pull out. unscrew the plug from end of hose and drain into pan. Pull the hose in and out for the best flow. When all water has drain, unscrew the large trap plug and remove debris if any. Use a flashlight and look into the hole after removing the trap. This is where I found more debris that I was able to remove with a coat hanger formed into a hook shape and I am back in business.
Posted on Sep 19, 2009
Displaying oe
LG's 'oe' stands for Open (door) Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 25, 2011 | LG WM2301HW Front Load Washer
Lg Tromm front loading washing machine. Model # WM0532HW.I keep getting the UE and IE codes. Also makes alot of noise in the spin cycle....warranty is done....should I not bother & get another
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too small, too large objects between tubs
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service notes and manual
Jul 23, 2011 | LG WM-2277HW Front Load Washer
Hi, we have a lg wm0532hw tromm front loader washer, the latch on the door seems to be broken, it slides all the way back into the door frame and washer will not lock. Can this be fixed? thank...
I'm sure it can but you will need to call a local service engineer to do it. Sorry we cannot call one for you.
John C
Mar 10, 2011 | LG WM-0532HW Front Load Washer
Lg tromm front loader washer wm0532hw shows oe error
that's draining error. check the filter cleanout behind lower left panel on front of machine; of course drain 1st via small drain hose. if thats o.k the drain pump itself may be jammed with debris or the drain hose could be clogged.
Jun 24, 2010 | LG WM-2277HW Front Load Washer
Lg washer oe code pump pluged
open panel small door on left front panel. empty water and clear pump.
Feb 13, 2010 | LG Washing Machines
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
LG Tromm WM2277HW OE error message
unit not drainning..in the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
Jan 25, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2032HW front loader washer gives error goes OE and IE
"OE" is really "DE"= drain error. Clean out filter behind access door on lower left corner front panel of machine. (there will be some water in machine)
"IE" = inlet error. machine took too long to fill. clean out inlet water screens where the hoses connect onto machine.
Oct 02, 2008 | LG Washing Machines
LG WM0532HW
I found a part number for a switch: http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/WM0532HW/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6600FA1704X/New.aspx To see the full list of parts for this model: http://www.partstore.com/Model/LG+Electronics+Incorporated/LG+Electronics%2fZenith/WM0532HW.aspx
Sep 02, 2007 | Washing Machines
Locked door with a OE problem code
Check the filter located at the bottom left hand corner. There is a door that you can open and pull out the filter.
Nov 27, 2006 | LG WM-2277HW Front Load Washer
Washing Machines Logo
1,667 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
