Question about LG LB1200ER Air Conditioner
Blowing circut my lg a/c keeps blow the circut it's plugged into
  • 22 Answers
Well with air conditioners, you need to plug them into a circuit in your house that you will not be using for anything else, whether that be lights, computer, etc... because portable a/c systems like that can take up to 15 amps which is what the average circuit is designed for. If you do have it as the only thing plugged into that circuit in your home, then it could be that the unit is going bad and is drawing too much current, or the electrical system in your house is not operating correctly. To which if it is either the unit or your electrical system and not just an overload of appliances, then you'll need to either get the a/c fixed or replaced, or have an electrician come out and check out the system.
But check to make sure you don't have anything else on that circuit of your house other then the a/c unit.
Posted on Jul 19, 2009
Lg 29'' flatron tv circut diagram
Check the LOT. If it is faulty, horizontal output transistor will blow out. Check the capacitor connected across the collector of the horizontal output transistor to Gnd. If it is bad, or have any loose solder terminals, H-Out transistor will blow out. If you wish to get more http://electronicshelponline.blogspot.com/ check this link. Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 22, 2013 | LG 29" Stretch LCD 17:6 aspect Mo TV
KEEP BLOWING THE FUSE AS SOON AS IT IS ENTERED IN THE FUSE BOX.
If you can pull the plug from the wiper motor and try fuse. If no change disconnect the plug to the electric windows and try fuse. Unlikly to be in dome light circut unless you have had aftermarket sterio system or other accessory fitted recently
Nov 28, 2012 | Cars & Trucks
Fuse 13 keeps blowing on 96 f150 why
If a fuse keeps on blowing you got a short in that circut, Thats why.
Nov 12, 2012 | 1991 Ford F150
Power window fuse keeps blowing
If a fuse keeps on blowing there are broken wires or a short in the circut controling them.
Nov 02, 2012 | Pontiac G6 Cars & Trucks
Why does my fuse keep blowing
If its the correct size fuse you have a short causing the fuse to blow. if its a fuse to say the a/c compressor, the compressor is pulling over the fuse size and causing it to blow.
Aug 17, 2012 | 2002 Saturn L-Series
Maytag RSW2700 - S/N R923415 ... has stopped working and is blowing circut. When cirdut reset ,, fridge plugged back in .. blows circut. I have lowered the temp setting, unplugged everything else but the...
Hi, The compressor is not starting and blowing the circuit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 19, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
1988 Mercedes Benz 560Sl The fuse for the A/C and heat control keep blowing I changed it and the A/C is very cold but the fuse keeps blowing when the fuse blows theirs nothing . no air blowing...
right if the fuse blows there should not be any air blowing. Anyway this sounds like your have a bad ground in the circut this is running on. Simply get a meter and check the circut from the battery all the way around ac circut and back to the battery. you will find it as auto electronics are very simple once you put aside your fear of it and realize that it current starts at the battery and ends there. Follow the ac's circut and the problem will be found. good luck
Apr 17, 2011 | Mercedes-Benz 560-Series Cars & Trucks
Hatco c-9 booster heater won't heat, 1 amp fuse keeps blowing
that is in the control cicut the contactor might be bad and taking out cntrl fuse.unhook contactor control voltage by unplugging from contactor tape off the two wires put new fuse in turn on power if fuse does not blow replace contactor.if it does blow you will have to isolate the next thing in the control circut maybe the light.you can buy resetable 1amp circut breakers at grainger for test purposes.sometimes on people I know I will wire in those breakers for them no more buying fuses.
Apr 11, 2011 | Hatco Corporation Compact Electric Booster...
Fuse for horn on 93 gmc sonoma keeps blowing
check the horns if you are short-circuited fuse burn
Aug 30, 2009 | 1993 GMC Sonoma Club
The fuse keeps blowing in my biozone 1500 induct unit.
get yourself a cheap multimetre, check for a short circut or open circut. this should be your first step. refere to google for info on short/open circuts. check the capasitors (small cylender things) for leakes or if the top is popped up on them. if so replace with the SAME. hope i was of some help
Aug 17, 2009 | Biozone InDuct 1500 Air Purifier
LG LB1200ER Air Conditioner Logo
66 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
