Question about Lexmark X2600 InkJet Printer
What printer driver do i install to get my printer,
What printer driver do i install to get my printer to work?
    President:
  • 846 Answers
Hello Maryjanebarr,
Click on the following link that I provided for you. It is for the latest driver to your printer. Download then install it and follow the onscreen instructions.
CLICK HERE FOR DOWNLOAD
Note:: make sure you uninstall any old printer drivers before installing this. Make sure to follow the instructions exactly as it tells you to. You should be set to go :)
Thank you for Choosing Fixya!
-Dan
Posted on Jul 19, 2009
  • 446 Answers
You need to determine first what is your operating system say, Vista or XP first, then you can download the required driver to lexmark.com
Printer connected to a Asus router RT-n56u via usb port System with Windows 7 Ultimate 64Bit Usb port enable through Asus Printer Utility Driver select (auto) during installation SAMSUNG UNIVERSAL PRINT...
I'm having the same issue with the same router and printer (mine is CLP-300/XXA).
At first when I try t print a pdf file or an image or any text/word document file with pictures/images I get an SPL-C error.
I have upgraded the firmware and it worked great on my laptop! Then, I tried to install the printer driver on my desktop, but now none of them work correctly.
Still not solved, but here are some suggestions:
1. Try to upgrade the firmware. 2. Try to install the original samsung printer driver 3.0.1
3. If it didn't work try to install the updated driver 3.0.4 4. If it didn't work try to install the Universal Printer Driver
5. IMPORTANT: between uninstalling and installing driver, disconnect both printer and router A/C power adapter and try to reboot you PC after removing the previous driver!
I'm going to work on it and see if it works. The DD-WRT firmware solved the exact same problem on my previous RT-N13U router, but unfortunately DD-WRT doesn't support RT-N56U yet!
Note: I called ASUS and they told me that Samsung printers are not supported for printer sharing server :(
Jun 19, 2011 | Office Equipment & Supplies
I lost my install cd and i cant install the printer lexmark x1270. already downloaded and installed the driver for it but still it doesnt work
1st You download Printer Driver. Lexmark Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Apr 20, 2010 | Lexmark X1270 All-In-One InkJet Printer
While trying to print from a microsoft works spreadsheet...it always says "out of memory" and prints a distorted page.
Hi
here are some ways to override the problem
When you try to print
it says
Microsoft Works Out of Memory
This problem may occur if there is a problem with the printer driver that is installed on your computer.
  • Method 1: Install a different printer driver
    Contact the manufacturer of your printer to inquire about how to obtain and install the most recent version of the printer driver for your printer.
  • Method 2: Configure the printer as the default printer
    Configure the printer driver that you have installed as the default printer. To do this, follow these steps:
    1. Click Start, and then click Printer and Faxes.
    2. Right-click the printer that you want to set as the default printer, and then click Set as Default Printer.
    3. Click File, and then click Close.
    4. Start Works, and then print the spreadsheet or the database file.
  • Method 3: Install an emulation printer driver
    If the problem persists after you install the most recent version of the printer driver for your printer, install an emulation printer driver. An emulation printer driver is a driver that imitates the functionality of a different printer driver. For example, you may be able to resolve this issue if you install the driver for the Hewlett-Packard DeskJet 550C printer or for the Hewlett-Packard LaserJet II printer. To do this, follow these steps if the printer is connected directly to the computer:
    1. Click Start, and then click Printers and Faxes.
    2. Double-click Add Printer.
    3. Click Next, and then click Local printer attached to this computer.
    4. In the Use the following port box, select the port that you want to use.
    If the printer is connected directly to the computer, the port is typically LPT1 (Recommended Printer Port).
    5. Under Manufacturer, click the manufacturer of the printer driver that you want to use as the emulation driver. For example, if you are installing Hewlett Packard 550c, click HP DeskJet 550c.
    6. Under Printers, click the model of the printer that you want to use as the emulation driver, and then click Next. Select HP. In Drivers, select HP DeskJet 550c.
    7. In the Printer name box, type a name for the printer, click Yes to set the printer as the default printer, and then click Next.
    8. Click the appropriate option for sharing the printer, and then click Next.
    9. Click No, and then click Next.
    10. Click Finish.
    Note If you are using a USB printer, go to step 12.
    11. Start Works, and then try to print the spreadsheet or the database file.
    12. Open Control Panel.
    13. Open Printers and Faxes.
    14. Right-click HP 550c, and then click Properties.
    15. Click Ports.
    16. Click USB001 Virtual Printer port for USB.
    17. Click Apply, and then click OK.
    18. Start Works, and then try to print the spreadsheet or the database file.
Hope this will solve your problem
Jan 02, 2010 | HP Photosmart C5180 All-In-One InkJet...
Printer does not print
Did you install the proper drivers ?
Sep 13, 2009 | HP DeskJet 3820 InkJet Printer
When i install the printer driver on windows vista is not working
there is a problem on working with software in windows vista. .
try to install the windows XP
Jul 25, 2009 | HP LaserJet P2015 Printer
I have had this printer for about 2 years or so. It used to work. Now it gets frozen on the USB printer port page when I try to print. So I went to the dell printer driver page and downloaded the printer...
no need new printer first uninstall old printer drivers from computer then check your printer model number and download exact driver again then install.
Jul 13, 2009 | Dell 725 InkJet Printer
I cannot find a printer to work on Acer Aspire X3200 Vista
any printer will work in your PC...as long as your computer meet the minimum requirement for the printer u choose
before you install the driver..remove or Un install the other program and driver you installed earlier
and restart the PC
you must install the right driver...install the driver that compatible to your Operating System (Xp, Vista), when installing the printer select the right port where you connect your printer (USB, LPT).
they are some installation instruction that you need to install the Printer Driver and Utilities first...then connect the printer or Restart the PC and connect the printer....
goodluck
Mar 16, 2009 | Computers & Internet
How to install hp laserjet p1505n network printer in windows 98
I can not find a win 98 driver for your printer on the HP website. DO yu have the instalation disk that was writen for win 98? If not try installing the printer through  the control panel. Either printers/fax or through install new hardware.The first being the preference. Some of the win OSs have printr drivers already installed.
If this does not work out, then the printer has no drivr available for that version of windows and you ewither have to upgrade to Xp or use a different printer which has a driver for win 98.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us〈=en&product=3435671&
Jan 02, 2009 | Office Equipment & Supplies
Laptop doesn't recognise printer
follow instructions below,
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Install printer drivers from CD or from download.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note some peinter does not work on Vista
Sep 14, 2008 | Dell 725 InkJet Printer
Lexmark X2600 InkJet Printer Logo
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
