Question about Whirlpool Refrigerators
Model ed25rf compressor not running door on
Model ed25rf compressor not running door on unit was slightly open all night
  • Whirlpool Master
  • 1,606 Answers
If the compressor isn't running , tap the thermostat and seeif it starts . If so , then thermostat is problem . If not , overload/relay on the compressor . Both are inexpensive .
Posted on Jul 21, 2009
Model ED25RF freezes items in bottom crisper drawer. Other parts and drawers ok.
We run across customers that have this trouble from time to time with there refrigerators. The first question i usually ask if the have changed the temperature setting recently. If not try a over night defrost, open the doors and unplug the refrigerator over night. That seems to take care of the problem. Its also a good time to give it a good cleaning. Don't forget to clean your condenser coils to.
If it helped join or Google Plus please.
On Time Appliance Google
Jun 30, 2015 | Whirlpool Refrigerators
Tip
My refrigerator is not cooling, how can I fix it?
It could be one of several problems -
1) Failed compressor relay
2) Failed compressor
3) Failed component in the defrost system
4) Bad door gaskets
5) Failed door light switch
Questions to answer -
1) Is the compressor (large black domed item with three tubes (one stubbed) at the bottom back of the frig.) warm or hot? If cool, then you could have a failed relay inside the compressor enclosure. Unplug the refrigerator from the wall, locate where the wires go into the compressor terminal box. Remove the clip holding the cover, and pull the relay off the compressor. Inspect for evidence of burning. Replace if necessary and reinstall all covers. You should always hear a clicking sound when the compressor tries to start. If it does not start, and you hear it click again a few seconds later, then it's likely you have a failed compressor.
2) Was the condenser fan running? The condenser fan pushes rejected heat away from the condenser coil. If it's not running, it's hard on the compressor, and the refrigerator does not cool.
3) Was there thick ice buildup inside the louvers of the back wall of the freezer? Heavy ice buildup here is an indication of a failed defrost control or heater and requires further diagnosis to determine the problem. A knowledge of use of a volt-ohm meter is required, along with a willingness and ability to do some mechanical and electrical dis-assembly and test.
4) Was the fan running inside the freezer? Freezer fan should run when the compressor is running, but not during the defrost cycle (or it would slightly heat up the refrigerator.).
5) Look up my "Tips and Tricks" article on testing your door gaskets.
6) Open the door slightly and look inside as best you can. Is the light on or off? Continue to open the door until you see the light go on to confirm the light switch is working.
Following each of the above steps may not help you fix your unit, but will give you an indication of things to look for and describe when you post a request for help when trying top fix you refrigerator.
on Dec 13, 2009 | Refrigerators
LG LFC23760SB Refrigerator doesn't have power. The outlet is ok. Didn't have a power surge.
i think there is problem with your compressor unit. You need some maintanance or service of your refrigerator at regular period.
Jan 03, 2014 | LG LFC23760SB Three Door French Door...
Sub Zero freezer keeps running
What is the model number of your unit?
Oct 21, 2012 | Refrigerators
Not starting after being left open all night.
You may have burned out the compressor motor as it was forced to run all night trying to cool the unit with the door open. The compressor motors in home refrigerators are not designed for running continuously. Call 1-800-KENMORE for help.
Feb 11, 2012 | Kenmore Refrigerators
Where is the thermostat located on my whirlpool model ed25rf?
At the front top as you open the ref door.on thwe left
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 20, 2011 | Whirlpool Refrigerators
Model 5920991 kenmore side by side unit quit
Pull the fridge out and remove the bottem panel .find the compressor it is a black round unit.listen to see if the compressor is running should make a hummming sound if you put your ear by it.If it is not running check the starter relay. TO check it unplug fridge remove relay it is located on the side of the compressor with 2 or 3 wires running to it. remove it and shake it if it rattles or if there are burnt spots on it it needs to be replaced.Hope this helps. if so give us a4 thumbs up.THANKS
Mar 02, 2011 | Kenmore Side by Side Refrigerator
Left the fridge door slightly open last night and fridge turned off. How do I turn it back on? Freezer is fine
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
let me know if this works.
Feb 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
Coleman rooftop unit ac only.
These units should run in higher ambient conditions within limits. If your unit shuts down with an ambient temperature of 95°F there is a possibility that the system may have a slight over charge of refrigerant in the system or a slight undercharge. This can be easily checked under running conditions by checking the superheat of the gases returning to the compressor. You may also want to check the current draw and the voltage supply during these conditions that are causing the system shut down.
Sep 22, 2008 | Coleman Mach 15 Air Conditioner
Refrigerators Logo
309 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
