Question about Kenmore Kitchen Ranges
Oven won't light, no gas
Kenmore gas oven 362.7525190. Top burners work and light fine. Oven won't ignite, and no gas (tried lighter)
catriver
  • 878 Answers
SOURCE: burners don't receive gas though oven/broiler does
tommi, this model has a cooktop lock-out solenoid feature. Try pressing and holding the top light keypad for 5 seconds and see if the top comes back to life. If not, check your owners manual, it may be a different key. The lock-out solenoid is in the back behind the outer panel. The cooktop lockout valve has been redesigned from a AC to DC voltage because of complaints of chattering. The new part number is 8184768. Lets hope you don't need it and just have the top locked out.
Posted on Apr 10, 2007
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
SOURCE: clock,timer and oven does not work on Kenmore gas Range
I was turning the timer and clock knobs on my oven and now it won't work. I don't know what position they are supposed to be in ... any ideas?
Posted on Mar 11, 2008
  • 1314 Answers
SOURCE: GAS STOVE
yep replace the bottom ignightor take out the rackes remove the two bott screws in the oven remove the bottom plate and just keep going down
Posted on May 21, 2008
aborcass
  • 2651 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
bad oven ignitor is the most common cause of bake failure, located onthe side of hte burner bar itself, if youd like with a multi-meter, you can check the wires leading to the ignitor for 110v. if you have power and nothing was glowing from ignitor theres your problem
Posted on Nov 23, 2008
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
My Kenmore gas oven does not light.
Remove the oven Racks. Remove the oven base plate. Turn the oven on. You can then see the oven ignitor next to the oven burner. If the oven ignitor does not glow a bright orange,replace it. About a $90 part.
Oct 05, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Burners don't receive gas though oven/broiler does
Apr 10, 2007 | Kenmore 75844 / 75849 Gas Kitchen Range
Kitchen Ranges Logo
95 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
