Washer makes loud vibrating noise when spinning. GE stackable washer dryer
    Sergeant:
  • 187 Answers
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion........
Posted on Jul 20, 2009
What does a blinking green light on a GE stackable washer/dryer mean
Can you provide more information on the year of your stackables and if you have the exact model or serial number, that would be helpful. Thanks.
Jun 02, 2016 | GE Spacemaker Washer and Dryer Electric...
My GE stackable washer is pouring out water while filling up, when spinning makes horrible noise and tub goes crazy
The issue is that a shock or spring that balances the tub has come loose and pulled a hose off when it broke. So the shocks or the springs are bad. The hose might be able to just be put back on.
Feb 23, 2015 | General Electric GE 5.4 cu. ft. Large...
Loud knocking during spinning
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 21, 2011 | GE WSXH208A Front Load Washer
Makes a loud noise in spin
heatman101
Sep 22, 2010 | GE Energy Star WCVH6260F Front Load Washer
Washer stinks terribly and has become so loud you can hardly be in the room when it is on.
Check out this tip I wrote about the noise and vibration thatfront load washers can make..
heatman101
Sep 18, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
Feb 18, 2009 | Washing Machines
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
Washing Machines Logo
245 people viewed this question
Top Washing Machines Experts
