Question about Plantronics Discovery 925 Bluetooth Headset
What do the lights mean on the xx9 plantronics 925? When will I know when is fully charged?
SOURCE: I need to know how
set your phone to discovery mode. press and hold the button inside of the diamond until it flashes blue and red. once you do that, your phone should see it. Pair it to your phone by putting in code. 0000.
Happy Calling :)
Posted on Dec 23, 2008
SOURCE: instruction on how to wear plantronics 925 bluetooth
The round portion that has the smaller hole in the center, with the small extension, goes into your ear. The squarish loop then needs to be rotated to out, so that it is "hooked" into the curve of your ear. Try different sizes to get the right fit of the loop (the bodies are identical).
Posted on Feb 13, 2009
  • 13 Answers
SOURCE: switching on discovery 925
Switch the bluetooth function on your phone, search for devices and then pair with your headset once it finds it. Allow it to connect without confirmation and leave your bluetooth switched on on your phone. Everytime you turn on your headset it should connect automatically.
Posted on Apr 10, 2009
  • 32 Answers
SOURCE: It will not turn on after a full charge
Sounds like you have a bum unit.  Plantronics gives a 1 year warranty with every wireless product, I'd send it back.
Have you made sure that you're turning it on correctly?  You push the call answer button and hold it down for about 3 - 5 seconds before it turns on, until the blue light turns on.  Make sure that you don't hold it longer than that or it will go into pairing mode.
Posted on Apr 28, 2009
SOURCE: how to connect the LG Voyager - plantronics discovery 925?
From all my research in the past few days (1-11 March 2010) I have found out that bluetooth hands free via bluetooth is not possible with the Motorola Droid or the Eris Droid. The problem is with the Google android operating system not your bluetooth device. After calling Motorola and Verizon tech support, both say that "They are working on it." I really hope they update/fix their os because I really want to buy a couple of their phones. They said to wait until 31 March 2010. Hopefully they will get their act together.
Posted on Mar 11, 2010
I have palntronic bluetooth but when i connet to other device like iphone it will never charge at all and the lights dont blink anymore when i plugg the thru my charger.
You need to use the charger that comes with the headset. It will not charge through any other device. Please follow carefully the instructions on this link for the Plantronics Discovery 925 User's Guide.
Good luck from Headsets Direct!
Sep 05, 2011 | Plantronics Discovery 925 Bluetooth...
Problems with dicovery 925 keep blinking purple light and can't pair with the phone help
Something you may want to try is start from the beginning. Check to make sure there are no other bluetooth devices loaded onto your phone that might interfere with the process. Turn off your phone. Disconnecting the battery of your mobile for 30 seconds and reconnecting helps to reset the phone. The instructions for turning off the headset and re-pairing the two devices are located in the following link for the Plantronics Discovery 925 User's Guide.
Sep 03, 2011 | Plantronics Discovery 925 Bluetooth...
I can hear the person on the other end, but they can't hear me on my plantronics Discovery 925
Try using the headset on a different phone. This will narrow down if it's a compatibility issue with your phone or a defective headset. If you pair to a different phone and experience the same dead microphone, that means the headset is the issue. If it's less than a year old, you can have it replaced directly from Plantronics. Plantronics tech support can be reached at 1-800-544-4660 x 5538.
Good Luck from Headsets Direct!
May 18, 2011 | Plantronics Discovery 925 Bluetooth...
When I make a call using the bluetooth, I can hear who I am talking to through the bluetooth, but they can't hear me?????
Make sure both devices are fully charged. Turn off your phone and disconnect the battery for about 30 seconds (this helps to reset the phone). Make sure there are no other bluetooth devices interfering with the connection. Turn off your headset and carefully follow the pairing instructions on the link below for the Plantronics Discovery 925.
May 12, 2011 | Plantronics Discovery 925 Bluetooth...
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
    until the headset begins to flash red and blue.
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    Sep 04, 2010 | Plantronics Discovery 925 Bluetooth...
    Apr 26, 2009 | Plantronics Discovery 925 Bluetooth...
    Switching on discovery 925
    Apr 10, 2009 | Plantronics Discovery 925 Bluetooth...
    Owner manual
    i jus need the owner manual for plantronic discovery 925, the dint send me the manual,i have bunch the bluetooths but a want to try this,if you can help me send me 1 copy is ok if not is ok to , i not gonig to $39.00 dolr for the manual, idont want tecnical suport like a say i just need the owner manusl, thanks,ifo you want to charge $39.00dlrs for the manual i prefer buy new plantronic 925 for anohter $10.00 dlrs ,thank any way
    Apr 08, 2009 | Plantronics Discovery 925 Bluetooth...
    Plantronics Discovery 925 Bluetooth Headset Logo
    90 people viewed this question
    Top Plantronics Radio Communications Experts
    LeAnna Mathews
    LeAnna Mathews
    Level 1 Expert
    shaun taylor
    Michael Vincent Cruz
    Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
