Question about Optics
I need to replace the top device holder on a T-50 Rokinon tri-pod. where can I find the part?
Not sure which model you have, nor am I familiar with this make but looking at a couple of advertised models suggests the mount may be similar to those used by Skywatcher and some other less-known Chinese brands. If you can make a direct comparison with the Skywatcher mount (EQ1, EQ2, EQ3 etc), try contacting one of their resellers.
Posted on Jul 23, 2009
Why wont lid on my phillips senseo hd7863 close when the pod is in the holder ?
Maybe you inserted the pod with the wrong side up or you used a 2-cup pod in a single cup holder. If the clamping spring isn't working (the lid feels loose when you try to close it), that spring (that is nothing more than a straight piece of metal wire) needs to be replaced.
Jun 07, 2014 | Philips Senseo HD-7810 Coffee Maker
I have a Baby Gaggia, several years old. I buy IZZO ESE pods, which I understand should fit the holder. They do not in that a pod sits loose in the holder, with a margin round the edge between it and the...
Please try the following:
  • Remove the portafilter and activate the brew switch. Water should stream out of the shower screen. If not you need to clean the group components, or the machine is broken.
    To clean the group components, remove the center screw. The screen should drop down, the dispersion disk may be stuck, you can pry it loose with a flat head screw driver. Soak both of these in a descaling solution.
  • With the group components removed (as above) try brewing, water should stream out of a single hole. If not, you may have a faulty pump, or seals.
  • If water streams out normally, be sure that you are using the single espresso basket. This is the smaller basket that snaps into the portafilter, and has sort of a tulip shape.
  • Your group head gasket may be worn, and will need to be replaced. These need replacement ever 6 months to 12 months, and need to replaced even if the machine is rarely used, because they are made from natural rubber that dries out.
    Replacements can be found at many retailers online, a few are:
    espressocare.com, espressoparts.com, and seattlecoffeegear.com
Mar 02, 2011 | Gaggia Baby Espresso Machine
Dyson dc11 replacing motor
DYSON DC-11 MOTOR REPLACEMENT
1. Remove dirt cylinders as normal
2. Using large flat screwdriver, remove airway splitter and hose
3. Undo 6 Torx screws from top and one at the back under tool holder
(Note that 2 front screws are shorter)
4. Make sure the screws are completely withdrawn
5. From the back, withdraw tool holder section
6. Unhook and withdraw hose holder section
7. Place large flat screwdriver behind the wheels and forcefully snap them off
8. Remove 2 more screws under each wheel
9. Cover now lifts off
10. Motor pod is now visible. Remove its 4 screws and lift its lid
11. Motor can now be lifted out. Disconnect its 2 wires
12. Remove the rubber base and transfer to the new motor
13. Connect wires, Red to Brown (Live) and Black to Blue (Neutral)
14. Make sure motor is correctly fits on its alignment studs in the pod and replace its cover and 4 screws
15. Replace top cover of machine, and the 4 screws under the wheels, but no other screws yet
16. Turn machine on its side and hammer each wheel back on - take care that no fingers are under wheels while doing this
17. Stretch and snap hose holder back into position
18. Slide tool holder forward into position
19. Replace the 6 screws into top section, and one into tool holder section
20. Replace filters, airway splitter and dirt cylinders, and the job is complete :D
May 22, 2010 | Dyson DC11 All Floors Bagless Canister...
Top will not unlock
It seems to be caused by pressure build up (not a vacuum) when the outlet of the pod holder gets blocked. There are three plastic bolts that slide into place to lock the lid as the lever is operated. Pressure forces the lid up and increases the friction on the bolts to the point where they won't operate. Solutions 1 and 2: First disconnect Senseo from the electric supply. Solution 1 is to press down on the lid to overcome the pressure and then operate the lever to unlock. Didn't work for me. Solution 2 is to get a table knife, not sharp, no serrations but with a rounded end, not pointed. Insert under lid just to right of pod holder handle, at an upwards angle of about 20 degrees to the horizontal. Then aim for the opposite 11 o'clock position on the closed lid. With a few tries the knife blade should slide between the top of the pod holder and the rubber sealing gasket releasing the pressure. Beware hot steam/water as pressure is released - wear gloves. Open lid, unblock pod holder hole with a pin, fill and heat resevoir and then flush through without a coffee pod in place.
May 21, 2010 | Philips Senseo HD-7810 Coffee Maker
Philips senseo coffee is watery
It may be the pod holder,there is a seal under the black disc at the bottom of the holder,the water will bypass the coffee under pressure,travel to the outside of the pod holder and exit the centre where the filter mesh is,if there is no foam also this is a sure sign,fill the empty pod holder with water and see how quick the water drips,I had this same issue and bought a new pod holder and compared,should be no more than 1 drop a second,you can knock the plastic out and re seat the O ring or buy a new holder,hope this is of use to you
Dec 27, 2009 | Philips Senseo HD-7810 Coffee Maker
I have the Keurig Gourmet Deluxe Home Brewing System #B60 When the pod is in place with the cover down the water won't come out while brewing. It will not make a brewed cup of coffee. If I remove the pod...
Check that pod has a punctured hole on BOTH ends.. If the bottom or to wear not punctured this will happen with most Keurigs.
Replace the pod holder if defective.
May 18, 2017 | Keurig Coffee Makers & Espresso Machines
Metal pin does not poke thru the pod
Do you need the top or bottom one? either way we have them here; http://www.igotsweetdeals.com
Oct 16, 2009 | Keurig B50 Coffee Maker
Can't pair garmin forerunner 50 with hrm and food pod
First you have to assume the battery that comes with your HRM would be new - keep in mind that it may be stored in the warehouse for many moons.
Given that, open and take out the battery - that should make a hard reset on the HRM itself. Restore the battery and try the manual pairing again.
The heart icon should pop up again.
Otherwise, you have to suspect the battery is low and need to be replaced.
Good luck
Jun 05, 2009 | Garmin Forerunner 50
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Stuck senseo maker
The locks shut due to a pressure build up in the pod chamber usually caused by a blocked filter in the centre of the pod holder.
The only way to open the unit is to releive the pressure. The pressure will normally reduce over time, the duration being determined by the pressure build up, condition of pod seals and the strength of the blockage.
A quick DIY solution: (small cable tie and screwdriver required)
Un plug the unit from the mains:
Remove the water container and prise open the rear snap fit panel of the unit carefully using a screwdriver to expose the internal workings, the overflow pipe at the top of the cover must be disconnected to gain enough access to work on the unit.
.The small metal boiler in the centre of the unit is used to heat the water for the machine, if the boiler is still hot allow it to cool down sufficiently for work to commence.
The exit pipe at the top of the boiler feeds directly to the pod chamber, if you squeeze this pipe you will feel that it is under pressure. Cut the cable tie connecting the pipe to the boiler (be careful, dont cut the pipe) and remove the pipe to release the pressure, a small ammount of water will be released during the procedure. The lid should open.
Reconnect the pipe to the boiler replace the cable tie, refit the rear cover making sure to push the overflow pipe back on before you snap the cover shut.
Remove the pod holder and clear the blockage blow through the holder in the reverse direction to ensure the filter is clear.
Replace the pod holder and pour a small amount of water on to it. The water should exit through the delivery spouts if the path is clear.
JOB Done.
Oct 28, 2007 | Philips Senseo HD-7810 Coffee Maker
Optics Logo
71 people viewed this question
Top Optics Experts
james laughton
james laughton
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
