Question about Canon PowerShot A430 Digital Camera
Memory card error
My canon powershot s400 has "memory card error" on the display and won't play or re-play any pictures. In the past I have fixed this by inserting the original canon card, but this time its not working
Help
Geobard
Hi,my powershot camera A-430 suddenly stopped shooting.Display shows "lens problem".I had bought it a few months back.I lost the original bill and other papers due to shifting of my house.Can u help me out?
Posted on Dec 17, 2008
Recall still in effect march 2008
Posted on Mar 27, 2008
  • Canon Master
  • 4,738 Answers
Canon will fix this for you for free. It's an inherent fault with the S400. It has a little internal button battery that causes the problem as it gets old and run down. Check this website for more info. Look for the bright/bold yellow post describing how to return to Canon.
Good Luck!
Posted on Dec 09, 2007
My Canon powershot s400 camera won't read memory card
First, remove the card, and look in the slot for any bent flash card pins. If you see any, don't fret, it's possible that you can fix this yourself. See this article on how to unbend flash card pins.
But if no pent pins are seen, then the camera's clock battery has worn out, and is likely causing this problem. Unfortunately this battery is internal to the camera. But Canon will fix this for you (for the S400 only) for free, with free shipping. Please see the Canon advisory for your camera here.
Sep 12, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Distorted image on LCD is what I get in the photo. I got a Canon IXUS400 and the LCD display is blurry and the picture is also blurry. I got of the plane and turned on my camera and saw this. Not sue of...
Canon has recognized that the IXUS400\S400 camera had two manufacturing defects. One is a memory card error and the other is the CCD image sensor which can cause the LCD screen to act dysfunctional. Contact Canon. They will fix these issues for free. Even if the camera is out of factory warranty.
Aug 17, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Blury lcd screen, but now sometimes the screens black. I also have a memory card error
Canon had manufacturing issues regarding memory errors and also the CCD. They will fix this free of charge. Even if the camera is out of factory warranty. Contact Canon. They were very helpful and fixed the same issues on my S400
Aug 11, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
S400 memory card error. Turn on camera - display "NO IMAGE MEMORY CARD ERROR". Can not take pictures, can not display pictures. Have several memory cards - same message, different cards. If the camera...
The internal BIOS battery has run down and is causing this error. Don't attempt to fix this yourself. Canon will fix this for you for free, with free shipping, regardless of your camera's warranty status. See and print out the following advisory:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8777&keycode=2112&id=27465
Feb 21, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
My camera (Canon S400) says "Memory card Error" and will not allow me to take any pictures.
When a canon S400 displays a memory card error this means that it has experienced an anomaly. This means that you have to reformat the memory card. You can do this via the menu. Make sure that you backup the pictures on it using a CF card reader on your computer
Aug 24, 2008 | Cameras
Memory card error
The clock button battery inside the camera has expired. Canon will fix this for free (or if you want, will send you a replacement battery with instructions on changing it out). Read the following recall advisory, then contact Canon at 1-800-OK-CANON:
Jun 20, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Memory card error
On the old Powershot S400, this error was caused by a dead internal "clock" button battery. Fixing it required simply replacing the battery. But before you attempt to do that, would first suggest trying a different memory card.
Jan 20, 2008 | Canon PowerShot A540 Digital Camera
Memory Card Error-Won't take Pictures
Hi momincali - I posted a solution for someone that seemed to have the same problem as you. If you didn't see it, this is what I wrote:
I had the same problem on my PowerShot S400 as well as I couldn't reformat the compact flash when using the feature on the camera. The solution that worked for me was reseating a small battery (about the size of a watch battery) in side the camera. To get to it you have to take the case apart.
I found this solution by googling and typing:
powershot S400 E50 error
I'm not sure if this site will allow me to add the web link - but this link had a picture of the camera and where the battery is located.
http://www.pinoyhack.com/2006/09/14/canon-powershot-s400-fix/
I decided to try it, since I figured I had nothing to loose, becaues otherwise I'd be looking for buying a new camera. To my surprise it fixed my problem, but I do not know if this is a permanent fix. If you do try this - take note of where each of the screws come from. There were 4 different size screws around the case.
There seem to be a lot of complaints about this problem though.
Good luck.
Nov 21, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Memory card error
Solution:
1 set date to 31-12-2030 23h59 and switch camera off.
2 wait two minutes, day will be 01-01-2003 and camera asks you to set the date
3 take away memory card
4 set the date to today
5 insert memory card again
Now your error should be solved.
Sucess, Jonny
Nov 09, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot A430 Digital Camera Logo
284 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
