Question about Whirlwind FH-778 Air Conditioner
H/p is freezing up. and acoil is freezing up.w
Will seting the wall t-stat at 70 f. cause this ? and why ?
    Champion:
  • 233 Answers
Two things cause freezing of the coil, lack of charge or lack of airflow, filters, coil and blower assembly all need to be clean, the thermostat will not cause feezing as it is strictly an on off control for convienience
Posted on Jul 20, 2009
My refrigerator is not getting cold
Is the freezer freezing? Do you hear a fan motor running inside the freezer? If the freezer fan is working and the freezer is still getting cold, do you see allot of frost on the back wall of the freezer?
Freezer not cooling at all - t-stat or compressor would be where to check next
No fan running in freezer and freezer is cold - bad evaporator fan motor.
If fan is running and you have heavy frost on the back wall of freezer - unit is not defrosting. could be defrost timer or defrost t-stat
Mar 12, 2013 | Amana Refrigerators
My wall unit cozy heater goes on when I turn on the thermostalt but it goes out one minute later. What is the cause?
by pass the wall stat, pull the 2 wires off stat and twist together and if unit runs ok it is the stat if it does the same thing by pass the stat wire by disconnecting the stat wires from the valve a put a jumper wire between the (th) terminals.
Oct 10, 2010 | Cozy (W352E) Heater
Dehumidifier freezes up
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Jul 01, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Colman centrial air conditioner. A coil freezes up solid restricting all air flow. model # on the ID Plate on the A coil is MCB36CQD. Thanks for your help
This is the time of year for icing up acoils. Hot days and cool nights have something to do with it, however you might need to clean the acoil. Use a product called NON RINSE FOAMING COOLING COIL CLEANER from a hardware store. You spray it on and its foam pulls **** out of the acoil from deep within and then it goes down the drainpan and serves to open it up as well. Good stuff.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 02, 2010 | Heating & Cooling
Model 106 56569400 - Freeze side appears to be Ok. Refrig side not cooling to set temp 37. Current temp is 55-60. Door appears to seal properly.
If you have heavy frost build up on the back wall of your freezer you have a defrost problem. One of three things. Defrost timer, Defrost T-stat or Defrost heater. Usually problem is with the T-stat. If no frost make sure the evap fan is blowing. You should be able to hear a fan noise when opening freezer. If no fan noise replace evap fan which is located half way up behind freezer wall. Good Luck
Jan 27, 2010 | Refrigerators
The freezer side of our Whirlpool refrigerator isn't freezing
open the freezer door,do you hear fan blowing if you don't bad evap fan motor,replace it, if that's ok touch the back wall of freezer,remove second from bottom rack and touch back wall,if there is snow or ice there you have a defrost problem,take off the back wall and find out what part is bad,could be t-stat,heater,or timer depending on year,if you can find timer advance it with screw driver and if heater comes on you have bad timer,you'll need a meter to read out t-stat and heater
Nov 01, 2009 | Whirlpool ED5SHAXM Side by Side...
A/C NOT TURNING ON & T-STAT IS SET AT SET POINT
it will take some times depends on ambient temp
but the probleme is to avoid freezing
-1 clean the a/c mainly (evaporator) clean air filter
-2 check and set your thermostat
if not cheak for leak of freon and recharge
May 04, 2009 | Heating & Cooling
2 Air Conditioner Problems
Whinny noise is probably motor which needs some motor machine oil (hardware store).
Freezing is probably caused by bad de-icing switch or poorly insulated de-icing switch.
If you want to further pursue, let me know.
Apr 30, 2009 | Heating & Cooling
I set temp to 74 and stop at 70 and decresing.
Sounds like the variances are not set right. if I am understand you. You set the thermostat to 74 and the heater shuts off at 70? If that is correct then the variances are wrong or you have placed the T stat in a bad location where it is getting heat from a vent, wall where there is a appliance or in a very drafty location
Feb 10, 2009 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
91 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
