Question about GE WBSR3140DW Top Load Washer
Water will not shut off in washing machine
I bought a used GE Profile top loading washing machine, Model # WPSQ3120T2AA Serial # GR117183G. I installed this machine today and hooked everything up, ran a cycle through and found that the water will not shut off when it should; initial fill, end of rinse cycle or at the end of spin cycle. I am assuming that there must be a valve where the water comes into machine. Any ideas?
Thanks in advance, Chris
    President:
  • 512 Answers
Check to load size selector switch, sounds like tube came off of it. The tube goes from switch to bottom of tube, tells machine what size load and when to turn off water.
Posted on Aug 18, 2009
GE profile washer wont fill all the way with water. Can only wash 2 pants and 2 shirts and its set on extra large load.
A lid switch doesn't regulate water capacity and if the lid switch fails, the machine will not execute a complete wash cycle. If the washer functions but only at partial water fill for the selected load level... then the problem is likely a clogged pressure switch tube or a malfunctioned pressure switch. Got mine used online - fixed the very same issue.
Mar 19, 2014 | GE Profile WPRE6100G Top Load Washer
Leaking into wash tub
The water inlet valve needs to be replaced. It is not sealing.
Here is a link to the part you need.
Aug 13, 2012 | GE Profile WPRE6100G Top Load Washer
Ge profile model WPRE6100GOWT Does'nt aggitate and cold water dribbles out..I checked water source and screens both are good??
replace the watervalve what your water supply hoses connect to part number is # WH13X10024 around $30.00.... it will not agitate untill water has satisified the pressure switch.....pd_0026_363_wh13x10024?$pddetailsth$
Feb 23, 2011 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G Top Load Washer how do you bypass lid safety switch? Unit pumps but won't spin.
worst washer I ever owned how do you bypass water level so you can wash a comforter man I am so disappointed with this GE Profile energy saver if I can't move the water level up I'm going to put it out along the road a trash day and it's only 4 months old
Dec 19, 2010 | GE Profile WPRE6100G Top Load Washer
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
Touch Screen on GE profile top load washer is not responding.
There is probably a problem with one of the following:
* electronic control board
* touchpad
Feb 24, 2010 | GE Profile WPRE6100G Top Load Washer
GE Profile Washing Machine wont fill with water top loader
disconnect water lines from washer and check to see if sedement from water plugged up little screen filters
Jun 11, 2009 | GE Profile WPRE6100G Top Load Washer
GE Profile Top loading Washer Model # WSSR3120W1WW ---
The water diverter could be plugged. or the diverters solinoid has gone bad on the hotwater side. It is located on the diverter itself.
Feb 10, 2009 | GE Profile WPRE6100G Top Load Washer
GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
GE WBSR3140DW Top Load Washer Logo
260 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
