Question about Microwave Ovens
Hi I have an error message on my range that says F13. The model number is C970-688022
  • 4,472 Answers
First off unplug the unit from power for 30 seconds to reset the range. This will sometimes clear the error. If it returns then it sounds like your electronic oven control need to be replaced. Also how long have you owned the unit. If its still under warranty you will not want to try and "repairs" yourself. Please let me know if you need further assistance or warranty service information.
Thank you,
Lee
Posted on Jul 19, 2009
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Error code showing
Unless there is grease or moisture on the control circuit board, error code "SE" means you have a shorting membrane keypad.
On this model, the membrane keypad is not available as a separate part, so the control panel frame assembly (which comes with a new keypad) would have to be ordered and replaced. It's actually a pretty simple DIY repair.
It is part number W10258189 and you can get it for about $129 (subject to change) from the Pros here.
There is also a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad as per the photo below.
keypad_connector.jpg Some connectors have a lock.
Then move your circuit board into the new frame. Be careful, the display is made of glass.
Dec 03, 2013 | Maytag Microwave Ovens
-SE- error message
Sensor Error , qualified Tech can help you , could be anything from a fan to a faulty switch
Dec 03, 2013 | Samsung Microwave Ovens
For Model: URC517MP - Can you clarify Error Code C5
Hi ess0,
The Amana error code F5 means that you have a failed Electronic Range Control (ERC. The only way to resolve this problem is to have the Electronic Range Controller be replaced. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
May 31, 2011 | Amana RC17 Microwave Oven
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
Error code appears on Kitchenaid range.
Which error codes do you get? What model number is this oven?
Dec 31, 2010 | Microwave Ovens
I plug in my microwave and it works for a few minutes then a error message reads key pad shorted the model number is jvm1740dm1bb
That is the worst microwave that you can buy. GE give you 1 year warranty, after that they send you a maintanence plan $50/month. They change mine 3 TIMES during the warranty period, after that works for 6 months and brake again. Always the problem was the KeyPad. The guy that they sent never told me a real reason for that, so I think is manufacturing defect. I put my GE JVM1740DM1BB to the trash.DO NOT BUY GE AGAIN
Dec 15, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Upon plugging in the microwave, several beeps are heard and the touch screen displays "Touch Error". After a few seconds the error message goes away but the touch pad is not functional. The Kenmore model...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a full one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 08, 2010 | Kenmore 63792 Microwave Oven
Won't run because of constant error message saying "DOOR" .. I ear the latch door close fine.
It depends on the model number, but with some Whirlpools the door switch circuit is complicated and has a couple of fuses that can blow, resulting in a door error message.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
I'd also recommend this file on door switches.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Dec 25, 2009 | Whirlpool RMC275PD Microwave Oven
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
