Question about Gateway 5310S PC Desktop
Installing secondary hard drive in a gateway 5310s
I have a Western Digital Hard drive from an old dell computer - I want to install in the Gateway - (music on this harddrive). I have changed the jumpers to a slave but I can fit in in the pc and secure it.
  • HeathG May 11, 2010
    "I have changed the jumpers to a slave but I can fit in in the pc and secure it." Did you mean to say can't fit it in the pc and secure it? I'm not sure what your question is.
  • 201 Answers
In most new cases there are extra slots for extra hard drives, but as long as the ide or sata is hooked up it should work, and you can buy hardware and rig up something ,ive tested many hard drives without hooking up hardware,
the components on the hard drive should not touch other metal
Posted on Jul 19, 2009
Western Digital Hard Drive Help Needed
Hi, The drive you are connecting to this USB enclosure can be set up as an auto select, master, or slave drive by changing the jumpers. Suggest to check your USB enclosure manual to see what is required for this device as to the configuration of the drive jumpers. Regards, Rongg
Mar 29, 2014 | Western Digital Computers & Internet
NexStar TX Enclosure Problems
I think it is because the hard drive you are using is too old for Windows 8 I think u will have to upload that to another hard drive
Mar 29, 2014 | Computers & Internet
Using Western Digital Hard Drive as External Hard Drive Problems
OK! First of all try to disconnect all usb's from neighbouring usb ports as they might be using up too much current resulting in your HD not having enough power to be powered up properly! Also, try to use a different usb port.
If all these fail, please use a voltmeter (if any available...) to check if your devices actually function...
Hope this helps! If not, please report back!
I have a old gateway pc and I would like to install a Hard Drive from a Dell pc into it. Can it be done?
Swapping the hard drive from the Dell into the Gateway will not work because the Dell hard drive has been installed with Dell specific drivers and configurations.
When you install the Dell hard drive into the Gateway you need to wipe the hard drive and install a fresh copy Windows XP onto this hard drive and the Gateway device drivers etc.
Oct 29, 2012 | Computers & Internet
I HAVE A GATEWAY GT5026E DESKTOP , MY HARD DRIVE IS SHOT WHAT HARD DRIVE CAN I USE TO REPLACE THE OLD ONE AND WHERE CAN I GO TO GET A NEW ..
This model Gateway is installed with a
250 GB 7200 RPM Serial ATA hard drive
You can install any make of SATA hard drive you wish, you may like to install a larger capacity SATA hard drive.
These SATA hard drives can be purchased over the Internet or at any computer shop.
Mar 06, 2012 | Gateway GT5026E PC Desktop
What is the jumper setting for wd200bb 20gb hard drive for slave
Slave - Installing the new drive as the secondary drive:
If installing your new Western Digital hard drive as the secondary drive on the cable with
two IDE devices, move the jumper shunt on the drive to pins 3 and 4. If necessary,
configure the jumper on the other IDE device as Master.
May 04, 2011 | Western Digital Caviar WD200BB 20 GB Hard...
Hello, I have a WD external harddrive 2.0. I
the file may be hidden. check to be sure it is connecting to your computer
Feb 16, 2011 | Western Digital My Book Essential 1TB...
Wont load correctly
check the hard drive.western digital hard drives work good in this computer. ihave two of them.also windows xp home works good on this.or run the system recovery cd.lastly' re do the
windows installation.
Jun 03, 2009 | Gateway Essential 400 PC Desktop
Western digital Scorpio 120 G
Actually there is no solution, the hard drive is bad.
What I ended doing was recording the partition in iso. ( I had a Factory Partition)
Got a new hard drive 160G scorpio unfortunately it does not come with installation disc.
Installed Vista, and with vista created a partition and then installed the contents of the factory partition.
Feb 18, 2009 | Western Digital Scorpio WD1200BEVS 120 GB...
Gateway series 300 with 4000783 moBo, no visual
Gateway are most likely wrong. These Gateway cp's usually have a motherboard failure which stops the cpu socket working, replacing the motherboard is a far cheaper option than buying a new pc, restore windows using my rstore disk which uses your registered version of XP. You could put the hdd in a dell computer, set the jumper omn the back to secondary master or slave of either the primary master ( C:\) or the secondary master.Then copy the files you wnt to an external source or the dell pc.
Nov 17, 2008 | Gateway (4000782) Motherboard
Gateway 5310S PC Desktop Logo
93 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
