Question about Nokia 5130 Cellular Phone
And i reset the default settings but its the same problem
Hello. How can I reset Panasonic Lumix DMC-TZ60 to factory default? (Can I reset software and hardware?) Thank you for answer
Resetting by 'Software'
Resetting to the Factory Default Settings from the interface:
  1. Go to the interface of your camera by typing in the camera's IP address in the browser. Example: http://192.168.1.253/
  2. Click Setup, Maintenance, Default Reset, Reset to default and then click Execute.
Resetting by 'Hardware' Resetting to the Factory Default Settings using the Control button:
  1. Disconnect the 'DC IN' cable from the camera.
  2. Hold down the 'Initial Set' button.
  3. Reconnect the power adapter using the 'DC IN' jack while holding down the 'Initial Set' button. Release the 'Initial Set' button after 5 seconds. (The reset could take up to 180 seconds)
  4. When the 'Status' indicator changes to green, the process is completed and the camera had a Factory Default Reset.
Sep 11, 2016 | Panasonic Cameras
Tip
Fly secret codes
M90 reset user code: *2100#
M100 software version: ####0000#
M110 reset user code: *2100#
2040(i) reset defaults: *#987*99# Send
MX200 reset defaults: *#987*99# Send
MX200 software version: *#900# Send
SL300m reset defaults: *#987*99# Send
SL300m software version: *#900# Send
SL500m reset defaults: *#987*99# Send
SL500m software version: *#900# Send
MP500 reset defaults: *#987*99# Send
MP500 software version: *#900# Send
Set language to English: *#0044#
Set language to Russian: *#0007#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
on Jun 29, 2010 | Cell Phones
Tip
Service codes Chinese models
  1. Service codes "Chinese" models:
  2. default user code: 1122, 3344, 1234, 5678
  3. Engineer mode: *#110*01#
  4. Factory mode: *#987#
  5. Enable test mode COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
  6. Restore factory settings: *#987*99#
  7. LCD contrast: *#369#
  8. software version: *#800#
  9. software version: *#900#
  10. Service codes BenQ:
  11. software version: *#300#
  12. test mode: *#302*20040615#
  13. Service codes Pantech:
  14. software version: *01763*79837#
  15. service menu: *01763*476#
  16. reset defaults (phone/user code reset to default): *01763*737381#
  17. Service codes VK-Mobile 3xx, 5xx:
  18. software version: *#79#
  19. software version: *#837#
  20. service menu: *#85*364# (hold #)
  21. Service codes VK200, VK2000, VK2010, VK2020, VK4000:
  22. software version: *#79#
  23. service menu: *#9998*8336# (hold #)
  24. reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
  25. Service codes LG:
  26. software version: 2945#*#
  27. Service codes Sony-Ericsson:
  28. J100 software version: #82#
  29. Service codes Fly:
  30. M100 software version: ####0000#
  31. 2040(i) reset defaults: *#987*99# Send
  32. MX200 reset defaults: *#987*99# Send
  33. MX200 software version: *#900# Send
  34. SL300m reset defaults: *#987*99# Send
  35. SL300m software version: *#900# Send
  36. SL500m reset defaults: *#987*99# Send
  37. SL500m software version: *#900# Send
  38. MP500 reset defaults: *#987*99# Send
  39. MP500 software version: *#900# Send
  40. Set language to English: *#0044#
  41. Set language to Russian: *#0007#
  42. Service codes Konka:
  43. C926 software version: *320# Send
  44. C926 set default language: *#0000# Send
  45. C926 set English language: *#0044# Send
  46. Service codes GStar:
  47. GM208 (Chinese Nokea 6230+) engineering menu: *#66*#
  48. Set language to English: *#0044#
  49. Set language to Russian: *#0007#
  50. Service codes Motorola:
  51. Motofone F3 software version: **9999* Send
  52. C113, C114, C115, C115i, C116, C117, C118 software version: #02#*
  53. C138, C139, C140 software version: #02#*
  54. C155, C156, C157 software version: #02#*
  55. C257, C261 software version: #02#*
  56. V171, V172, V173 software version: #02#*
  57. V175, V176, V176 software version: #02#*
  58. C168, W220 software version: *#**837#
  59. W208, W375 software version: #02#*
on Mar 07, 2010 | Cell Phones
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
Tip
CHINA PHONES CODES
*#66*# Set Factory Mode CONFIRMED
*#8375# Show Software Version CONFIRMED
*#1234# A2DP ACP Mode CONFIRMED
*#1234# A2DP INT Mode CONFIRMED
*#0000# + Send : Set Default Language CONFIRMED
*#0007# + Send : Set Language to Russian CONFIRMED
*#0033# + Send : Set Language to French CONFIRMED
*#0034# + Send : Set Language to Spanish CONFIRMED
*#0039# + Send : Set Language to Italian CONFIRMED
*#0044# + Send : Set Language to English CONFIRMED
*#0049# + Send : Set Language to German CONFIRMED
*#0066# + Send : Set Language to Thai CONFIRMED
*#0084# + Send : Set Language to Vietnamese CONFIRMED
*#0966# + Send : Set Language to Arabic CONFIRMED
More some codes for reset mobile
china
*#77218114#
*#881188#
*#94267357#
*#9426*357#
*#19912006#
*#118811#
*#3646633#
CHINESE MODELS:
set English language (new firmware): *#001# Send
also
Service codes BenQ:
Service codes 3xx, 5xx:
Service codes LG:
Service codes Fly:
ZTE Mobileyahoo15.gif1- *938*737381#
2- PHONE WILL DIPLAYED DONE
3- POWER OFF YOUR PHONE AND POWER ON AGAIN
alcatelyahoo15.gifE205
unlocking phone code,only press***847# without simcard
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes BenQ:
Service codes LG:
KG300 NVRAM format: 2945#*# -> menu 15
Service codes Fly:
Service codes Motofone-F3:
***300* Set SIM Pin
***310* / ***311* SIM Pin ON | OFF
***000* Reset Factory settings
***644* Set Voicemail number
***260* / ***261* Auto keypad lock ON | OFF
***510* / ***511* Voice Prompts ON | OFF
***160* / ***161* Restricted Calling (Phonebook only) ON | OFF
***200608* Send: software version
***200606* Send: software version
***200806* Send: flex version
***250* / ***251* Keypad tones ON | OFF
***470* Select time format
***500* /***501* Prepaid Balance Display ON | OFF
***520* Change language
and "yes"''
-mobile Inno30, 55, 89, 90, 99, 100, A10, A20, P10, Vk200
- Set full factory *741*737381#
- Set full factory *741*7373868#
- Set full factory *741*2878#
- Set Engineer Mode *888*888#
- Check software version *888*837#
I-mobile 100 ,200 , 313
- Check software version #*888#
I-mobile 309, 310
- Check software version *0*4636#
- Test Mode *0*6268#
I-mobile 311
- Check software version #*878#
I-mobile 511
- Check software version *1222*1#
I-mobile 301, 302,308, 508, 601, 602, 603, 604, 606, 611, 901, 902
- Check software version *#159#
- Set Factory Mode *#32787#
- Set Engineer Mode *#3646633#
I-mobile 503, 506, 605, 600, 607, 608
- Set Engineer Mode ***503#
- Set Factory Mode ***504#
- Set Auto Test ***505#
I-mobile 509, 612
- Set Factory Mode *#66*#
I-mobile 504, 505, 803
- Check software version *68*48#
- Set full factory *789#
- Test Mode *#789#
I-mobile 305, 306, 315, 510, 609, 609i,516
- Check software version *#8375#
- Set Factory Mode 878
I-mobile 610
- Check software version *#22#
I-mobile J101, J102
- Test Mode *23638777*783781#
I-mobile 502, 502i, 505, k9, 802
- Check software version *201206*4636#
on Mar 11, 2008 | Nokia N95 Cellular Phone
How to hard reset or format samsung SGH-A777 since my screen has gone white and i cant see anything :(
To reset the handset, to the factory default settings, follow the steps below:
  1. While in standby mode, press the right soft key for Menu
  2. Select Settings (9)
  3. Select Reset Settings (8)
  4. Highlight, using the navigation keys, any of the following:
    • All: Sound Profile, Display, Phone, Alarm and Bluetooth settings will be returned to default values
    • Sound Profile Settings: Only sound profile settings will be returned to default values
    • Display Settings: Only display settings will be returned to default values
    • Phone Settings: Only phone settings will be returned to default values
    • Alarms: Only alarm settings will be returned to default values
    • Bluetooth: Only Bluetooth settings will be returned to default values
  5. Press the a737%20center%20key%5b2%5d.jpg key to check the box(es) of the desired Reset Settings
  6. Press the left soft key for OK to set the Reset
  7. Enter the password, using the keypad, default password is "0000"
  8. Press the left soft key for OK
  9. If prompted, Enter the password again to confirm, using the keypad
  10. Press the left soft key for OK
  11. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Jun 03, 2011 | Cell Phones
I have an sgh-a877, impression, and I can't find a reset button. Is there one on this phone?
  1. From the standby screen, press Menu
  2. Press Settings
  3. Press Reset Settings
  4. Press on any of the following to check their boxes:
    • All: Sound Profiles, Display & Light, Phone and Alarm settings will be returned to default values
    • Sound Profiles: Only sound profile settings will be returned to default values
    • Display and Light: Only display settings will be returned to default values
    • Phone: Only phone settings will be returned to default values
  5. Press Reset
  6. Enter the password default password is "0000", then press OK
  7. If prompted, Enter the password again to confirm then press OK
  8. Press Yes to Reset the handset's settings to the factory defaults
May 25, 2011 | Samsung Cell Phones
A767 got wet and now goes into downloading on screen and then locks up?
Sir, it's due to some problem in the Firmware. It better to reset the device.
For reseting your device either contact a service center of Samsung or do the following:--
  7. Enter the password, using the keypad, default password is “0000”
Or refer to this site: http://www.retrevo.com/support/Samsung-SGH-A767-Cell-Phones-manual/id/23135ag619/t/2/
Regards
Vineeth K.
Jul 20, 2010 | Samsung Propel A767 Cell Phone
MY PHONE IS LOCK AND I CANNOT UNLOCK IT. WHAT CAN I DO?
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/t-mobile-phones/SGH-T929ZKATMB/index.idx?pagetype=prd_detail&tab=support
Page 165 from your manual:
Reset Settings
From this menu you can reset your phone and sound settings to the default settings or perform a Master reset.
Reset settings
1. From Idle mode, touch Menu ➔ Settings ➔Reset settings ➔Reset settings.
2. Touch the check box next to each of the following that you want to reset
• All: Phone, Display, and Sound settings are returned to default values.
• Sound profiles: only sound settings are returned to default values.
• Display settings: only display settings are returned to default values.
• Phone settings: only phone settings are returned to default values.
3. Touch Reset.
Master reset
From this menu you can reset your phone and sound settings to the factory default settings.
1. From Idle mode, touch Menu ➔ Settings ➔ Reset settings.
2. Touch Master reset, enter your password, then select Yes to confirm.
The phone resets to the factory default settings automatically and when finished displays the Main menu.
Hope this helps, let me know if I can do anything else for you.
JimmyC
Oct 13, 2009 | Samsung Memoir SGH-T929 Cell Phone
Nokia 5130 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
