Question about Dacor ECD230 Epicure Electric Double Oven
Dacor touchpad on my dacor oven cps130 set temperature at 350 then shutoff tried several times and did same thing prior to that we were getting f1 code after cooking something...if i need a need touch pad need in white its discontinued where can i get discontinued dacor parts thank you nancy
  • 6,784 Answers
HI, this is a Element relay circuit failure. this relay is a separate PCB board with attached relays.
this relay board will need to be replaced.
CLICK HERE TO ORDER
Posted on Jul 19, 2009
F1 error?
Hi, The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Dec 19, 2010 | Maytag CWG3100A Gas Single Oven
Periodically get an F1 code when using top oven. Often, lowering set temperature will allow me to continue. Usually happens at 375 or above. Sometimes, error occurs at 350. Suggestions and advice would be...
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 12, 2010 | GE JKP55 Electric Double Oven
Keep getting F1 error code (constant beep) on my GE profile oven.
%#$TEF
Mar 18, 2010 | GE Profile JTP56 Electric Double Oven
When the oven is on 350 for 15 min the broiler goes on I un plug it then pulg it in the F1 comes on
$%$rt
Sep 30, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F1 message on Kenmore oven
Sep 14, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
Can't get oven to come on - get "F1" light and beeping
(*&yh
Apr 29, 2009 | GE Profile JTP18 Electric Single Oven
F1 keeps flashing...
*&^ty
Dec 13, 2008 | GE Profile JTP18 Electric Single Oven
Dacor cps130 wall oven f1 error
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Nov 06, 2008 | Dacor MCS130 Millennia Electric Single...
PCS 130 Keypad
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
May 22, 2008 | Dacor PCS130 Preference Electric Single...
According to the manual, this is an element relay circuit failure. Call the tech.
Dec 04, 2007 | Ovens
Dacor ECD230 Epicure Electric Double Oven Logo
616 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
