Door is open door lock is activate and door can't close reads: d5 error help!
  • 6,784 Answers
This is a defective door lock switch. you will need to have this damaged mechanism replaced asap, if possible.
Posted on Jul 19, 2009
Samsung front load washer code d5
The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. the problem is related to faulty door locking assembly.There is a switch in back of door, if this fails it wont work. God-Bless!
Nov 06, 2015 | Samsung Washing Machines
Error code d5
I am wondering if your error code is DS and not D5, which would indicate problems with the door lock assembly communicating with the control board. Essentially, the control board does not believe the door is closed and/or locked, so it shuts down the machine.
the service manual which will tell you how to do some testing of the door lock, but in the end you may need both a control board and a door lock assembly. The good news, they are easy to change out, the bad news, they are expensive parts so you want to be as sure as possible before you buy and install.
Jul 02, 2015 | Maytag Washing Machines
I have a amana front loader washer and it was doing its norman cycle and stopped at 35 min left and wont do anything and the door was locked so I unplugged it for a hour went back and pluged it in makeing...
This is an error involving the door switch, it is actually DS not D5. The door may not be closed properly, try pushing it in. Or you may need a replacement door switch.
Jan 27, 2015 | Amana Washing Machines
Samsung VRT with a DS or D5 code? Door closes but won't lock
bad door lock switch mechinism or the control board is bad at the emergency door lock circuit? where the wires from the door swtich attache, check ur schematic and will need a multimeter
Dec 18, 2014 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Washer won't stay running error code DS
Oct 16, 2012 | Washing Machines
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
When i try to start the washer code d5 shows ands chimes
Hi
The reason for d5 error is due to defective door lock switch. It is a door lock error code, more than likely a bad door latch it's an easy repair. When washer displays this code it means door is open while washer is running. Check the lid switch and striker.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Washing Machines
Not sure if this is the right wasing machine that matches ours or not but we are getting a d5 error and don't know what it means
The error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle.The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly.But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem. This has to be checked to confirm the fault.Keep updated with any more queries.Thanks.
Oct 14, 2010 | Samsung WF337AA Front Load Washer
When i turn it on it beeps and the letters d5 show up
hello,
this indication is an error code saying that the door of the washer is not well luck /close
what you are to do to solve the problem is to put off the washer from the power supply then on it again after some time then open then door and close it properly with care the d5 code will be solve
thank you and thanks for using fixya.
Jul 12, 2010 | Samsung WF337AA Front Load Washer
Error Code d5
It sound like a loose or a broken lid switch issue. The lid switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Good luck!
Aug 21, 2007 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
424 people viewed this question
Top Washing Machines Experts
